Used multimeter on door switch and start switch and both showed zero resistance. Checked circuit breaker
Check thermal fuse(white fuse on blower housing) and check heat circuit going through timer. Unplug first!
Testimonial: "I checked the thermal fuse and it was dead. I replaced it and tested the new one (working) but same result. I will look up the heat circuit and see if I can figure that out."
SOURCE: Tripping of circuit breaker
Check what other appliances are on your circuit. What goes off when the breaker is tripped. You may need to relocate the microwave to a different circuit. Try to stay away from the refrigerator or AC circuits.
SOURCE: Dryer does not start - Thermal Fuse is ok.
My Maytag Electric Dryer stopped working mid cycle and wont turn on at all now. Any ideas?
SOURCE: None of the Power Windows work.
What you can do is open the drivers door and there is a rubber boot between the door and the body.Peel it back and check the wires.The big wires for the window motors like to break here from the door being open and closed so frequently.Check them over very carefully.If possible slide the rubber boot as far one way or the other so you can see all the wires.You might be getting power to the switch but it might not be going back out.Hope this helps.Good luck.
Testimonial: "The answer was right on. The fix ended up being cheap and easy. Thanks much."
SOURCE: I have a roper dryer
No, reset button on these. It may be the lid switch or the thermal fuse. This is what I find most of the time. Check out the diagram on apwagner.com and you'll see the parts locations. Oh, if it's not the thermal fuse of the lid switch it may be the timer. I've seen this a couple of times.
SOURCE: Samsung dmt800rhs won't turn on. Only used
Hello, J
I was trying to help
you out here. I was going back to some customers that asked questions
in the past and it appeared that no one answered them, so I thought I
would take some of my personal time to see if I can help. Even though
this site may not have your exact model or brand, This link will help
you tons. Here is a link
to about everything you want to know about your dishwasher, from repair
to trouble shooting it,pictures, video's. Just scroll around and you
will see tons of information to almost any question you might have on
your dishwasher. If you go to this link and click around, I am sure you
will find out so much about your dishwasher, you will know more that the
company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time
to rate my help and some kind words written would be appreciated for my
free help , I would appreciate it. Here is also my direct link to my own
pages of other areas of my expertise for other problems you might have
in Automotive,Appliance, and Electronics. Drop In anytime for my help.
Thanks,Mike
http://beta.fixya.com/users/mc1bean
I tested the thermal circuit which was bad. Still not powering on after replacing it though
