Question about Samsung Office Equipment & Supplies
I put on my printer Samsung clp320 but after booting up the red light show up under the cancel button,how can I repair it
Posted by Samaila Yusuf on
Norman J Weimar Jr
  • Samsung Master
  • 6,960 Answers
Check the toner cartridges one may need replacing. check the printers web page for the error
Posted on Apr 07, 2019
4 Related Answers
edGent
SOURCE: printer
i have a pentium III on a P3WE5 motherboard from asus , and it keeps crashing when i click on 'about' in windows... or when the cdplayer is starting. Any idea?  I changes about every component on the motherboard and i am fed up with it :(
mail : [email protected]
Posted on Apr 06, 2008
Anonymous
SOURCE: My ML1610 Samsung printer is not working. The red
My ML1610 Samsung printer is not working. The red and green light are blinking simultaneusly and cancel button is struck. How can I set it right?
Posted on Jul 14, 2010
printmastert
Lexmark
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: red light under ink cartridge
    The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
    1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
    2. Open the printer cover and remove both the cartridges.
    3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
    4. Close the printer cover.
    5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
    6. When the printer turns on, reinsert one cartridge first.
    7. Close the printer cover and check the light status.
    8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
    9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
    10. Load some paper. Try to print a document again to verify that the problem is fixed.
    Posted on Mar 20, 2012
    jkhbwetgwer
    Roger
    SOURCE: ATT 2wire modem will not work. Red light on power button.
    Hi, It's your power cord. You need to purchase new one. take a look on amazon, here: Finally charging for our multi device world. I hope I have helped. Cheers
    Posted on Dec 03, 2014
    Cartridges has been replace but the error light is still blinking
    need to reset the printer. which usually means printing a test sheet and scanning it if your printer requires. press the power button and check if anything pops up on your computer, usually something comes up.
    Apr 21, 2013 | Samsung CLP320 AllInOne Laser Printer
    Cancel button is stuck
    Can you take a paperclip or something else like a nail file and gently pry the button up by sliding the small object beside it?
    Jul 11, 2008 | Samsung CLP-510 Laser Printer
    Clp320 reset counter
    If you are worried about opening the printer or welding, you can simply buy an easy reset chip from Amazon or eBay. No welding is required and the installation takes only 1 or 2 min. Just peel and stick the chip.
    Search for DRUM RESET CHIP or PEEL STICK DRUM RESET and you will find many premade reset chips.
    If you are familiar with soldering, you may buy a drum reset fuse only and save $$$.
    Mar 13, 2013 | Samsung CLP320 AllInOne Laser Printer
    When i print red, i get pink
    you might need to replace the laser cartrige, If its not that please tell me what you are trying to print (red picture or red text/writing)
    -DF
    Jun 08, 2012 | Samsung CLP320 AllInOne Laser Printer
    When I want double sided printing with samsung ml2010 printer, the online error stay red after one side is printed. Then i can do nothing but turn off the power button. it goes well when one sided...
    I solved it!! Just hold down the Cancel button and I think it acts as the OK button. The red light will go away and turn green and it will print the odd pages. There you go!
    Dec 18, 2010 | Samsung ML 2010 Laser Printer
    Samsung ml1640 laser red light blinking
    samsung ml1640 laser red and green light blinking continuously and printing not happening
    Jul 02, 2010 | Samsung ML-1640 Monochrome Laser Printer
    The on button keeps flashing and the red light stays on
    Try resetting your Canon PIXMA. Here's how:
    1. Turn the printer off.
    2. Hold the button Resume / Cancel (red triangle in the circle), click POWER - indicator lights green.
    3. Release the button Resume / Cancel, keeping POWER.
    4. Click Resume / Cancel 2 times, keeping POWER, and then release all the buttons.
    5. When the indicator light Green - click Resume / Cancel 4 times!
    6. Turn the printer off button POWER.
    Have a good evening!
    Jan 12, 2010 | Canon PIXMA MP170 All-In-One InkJet...
    Dec 15, 2009 | Samsung ML 1610 Laser Printer
    Red and Green lights are together blinking continiously
    I had this problem. The cancel button was stucked. Open the toner tray and slighly push the button side top-cover up. It released the cancel button for me (actually I was trying to open the top, but it worked). The cancel button was released and the blinking red-green stopped. Printer now working.
    Mar 03, 2008 | Samsung ML 1610 Laser Printer
    Online/error light
    Pull out the toner cartridge. Carefully put your fingers into the opening just beyond the chrome roller. A little to the left of center you will fell/see a small black plastic finger which sticks up. It should be loose - push it forward and it springs forward, release it and it returns to the original position. If your paper jam catches this finger it can become jammed and will feel rigid. Put light pressure on it either pushing to the back or pulling forward until it becomes free again. Replace the toner cartridge, close the cover and your red light should go out.
    It worked for me - hope it helps someone else.
    Mary Lou
    Aug 31, 2007 | Samsung ML 1610 Laser Printer
    52 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
