Question about Home Fencing
Do you have sensors that stop the gate closing on people or cars ? If so put your ear near the sensor but not inline with the opposite one. Now gently wave your hand in front of it .... if there is no click then something is obstructing the beam. Sometimes spiders get inside and spin that candy floss type web in there .
Posted on Mar 18, 2019
SOURCE: I need to program a centurion gate motor receiver
Your gate controller reciever only has one code. You must set all the remotes to that code?
Posted on Jul 23, 2009
SOURCE: Steps to program additional remotes for Centurion gate motor
hi
are the remotes sorted
Posted on Feb 23, 2010
SOURCE: Need to program Nova remotes on a Centurion D5 Motor.
Hi
Have you managed to program the remotes
SOURCE: I have bought an additional
Steps to Programming Centurion Nova Remotes 1. Unlock the motor cover with your Centurion Key, remove this cover. 2. Inside the perspex enclosure there is a small Receiver Board (approx size of a matchbox), identified by wording CENTURION CP9Z, also has the wording J1-Learn; J2-Erase. 3. There will be a small 'shunt' placed on one of the pins labelled J1, J2 or the centre pin - these are the 'Learn' pins. 4. Remove this shunt and place it over (or bridge) the J1 and centre pin together. The red LED Status light, to the left of the Learn Pins will illuminate. 5. Remove the new Remote/Transmitter from its packaging, hold down the required button once and the red LED Status light on the Receiver Board will flash once indicating that the button has been learned. As soon as the light has flashed, remove your finger from the button. 6. If further Remotes/Transmitters are to be added to the system, repeat step 5. 7. Ensure that you now remove the 'shunt' and place it back onto the blank or J2 pin - do not leave it bridging two pins. 8. Close the enclosure, place the motor cover back onto the motor and lock in place.
Posted on Nov 03, 2010
SOURCE: I have bought 2 new
On a D5 Motor To program the first remote place the jumper on in learn mode over J2 and Central Pin after it has completed flashing remove the jumper. Press the button on the remote you want to program, wait until the gate starts moving. To program addtional remotes use the master remote. First remove the jumper so that the 3 pins are exposed. Press the button on the master remote and hold it in. Notice that the LED next to the pins starts flashing after it has flashed 11 times release the button. Now press the button on the second remote and hold it in it should learn the signal.
Posted on Feb 10, 2011
Jun 11, 2015 | Sentry Televison & Video
Mar 12, 2014 | Televison & Video
Nov 27, 2013 | Televison & Video
Nov 25, 2013 | Televison & Video
Oct 18, 2013 | Televison & Video
Feb 22, 2012 | Televison & Video
Jul 29, 2017 | Garden
Sep 07, 2009 | Televison & Video
Aug 21, 2009 | Televison & Video
Jul 15, 2009 | Home Security
Apr 23, 2017 | Home Fencing
1,547 people viewed this question
