Question about Photography
Ist stage temp high
Nirvana n55 oil free
Please help!! my IRN55K-OF-N55 alarm "high intecooler press"
well a quick sub out of sensor in intercooler with a pressure gauge is a easy way to see if its a sensor failure or a intercooler blockage , i do believe that hole is tapped 1/8 npt pipe thread so a gauge screws on real easy
Apr 07, 2014 | Ingersoll Rand IRN7H-115 Nirvana...
Please help!!! my IRN55K-OF-N55 alarm "high intercooler press"
Your problem is valve discharge closed, so the pressure cannot out from inter cooler.
VSD fault 7 Problem with Ingersoll Rand Air & Gas Compressors nirvana n37 37kw
plz any one help us vsd 7 fault and the compressor does not start and the fault appears
Mar 21, 2014 | Ingersoll Rand Air Tools & Compressors
Where can i download for free a Nikon F55 user manual
You can find the manual for the Nikon N55 at http://www.butkus.org/chinon/nikon.htm
The N55 and the F55 are the same camera; the N55 name was used in North America and the F55 name in the rest of the world.
Jan 24, 2010 | Nikon Cameras
My Nikon N55 will not auto focus.
Depending on the type of interchangeable lens you have mounted on the camera, there may be a switch on the lens barrel for choosing between auto-focus or manual focus. The N55 also will not auto-focus with the newer Nikon AFS lenses such as those used with the Nikon D40 digital slr. Finally, there was a service bulletin on the N55 back in 2005. Nikon discovered a problem with the auto-focus and fixed it for free, but there may have been a time limit. Here is a link to more info about that:
http://www.nikonusa.com/Service-And-Support/Service-Advisories/N55-Service-Advisory.page
Hope this helps : -)
Nov 30, 2009 | Nikon N55 35mm SLR Camera
Nikon n55 manual mode f.stop and shutter speed controles
There is a downloadable PDF format Nikon N55 manual from http://nikoneurope-en.custhelp.com/cgi-b...  . Thanks to Ands for this tip.
Sep 25, 2008 | Nikon N55 35mm SLR Camera
Problem
http://www.nikondigital.com/main.html look at the service advisory link on the bottom right. It pretty much describes your problem, same model. you are eligible to a free repair. Good luck
Jun 10, 2006 | Nikon N55 35mm SLR Camera
Photography Logo
119 people viewed this question
Top Photography Experts
Ekse
Marvin
Marvin
Are you a Photography Expert? Answer questions, earn points and help others
