Question about Video Game Consoles & Games
I am having problems connecting my xbox 360 2 my dvd component
Posted by Colette on
Meli Dragon
    Sergeant:
    Habit-Forming:
  • 127 Answers
If you are going to stream and to make money with it, I can advise https://onetwostream.com/blog/ultimate-streaming-setup/ which is a perfect way to know more about streaming.
It can bring a lot of new emotions, money and different opportunities.
Posted on Feb 26, 2020
ASMR Game
    Habit-Forming:
    New Friend:
  • 20 Answers
I really like streaming and also to make money just like that.
Lionel Messi
Instead, for those who like to play games now, they all choose and download the free mod to experience the latest games. The place to allow users to download free games and applications at home page: https://techbigs.com
Posted on Feb 25, 2020
Giselle
    Genius:
  • Video Game C... Master
  • 1,015 Answers
You need reload it, if do not work, try to delete dates and run it again, or get a cd key for it, for cheap and legal cdkeys, you can have a view on http://www.m8x.com?aff=CPCD, games gold and games items are available there too
Posted on Apr 10, 2019
5 Related Answers
Anonymous
SOURCE: IP address Problem when connecting to xbox 360 live
i had the same problem buddy. The problem might be that you hacve another system on the wireless network that uses that same IP address. This can cause a conflict that will prevent the xbox from logging on. Try deactivating other systems on the network to see if thats the problem
Posted on Sep 26, 2007
Anonymous
  • 3 Answers
SOURCE: Xbox connectivity problem
As dumb as this sounds here is the mistake Sony made. The receiver does not process sound from the HDMI, it will only pass through that data to you TV. So you will not be able to get sound from your 5.1 speaker setup if you only connect the HDMI, you have to use the matching audio input for that respective HDMI input. Make sense? So the HDMI DVD Input must have digital coax for sound, HDMI Video2 must have fiber optic for sound, and there is another fiber optic port for the Sat input. Yes thats right, if you have 2 HDMI HD components and each only has fiber optic(neither one has digital coax) you cant hook both up properly the way you would think. Sony made this receiver poorly, turning High Definition Multimedia Interface into High Definition Multimedia Except For Audio Interface.
Posted on Jan 27, 2008
bobblebum
SOURCE: XBOX 360 Elite HDMI problem
I have same issue with my Xbox 360 Elite using HDMI cable from Microsoft on my Mitsubishi 57" 1080P.
Works fine with component cable upto 1080i, get nothing using HDMI cable.
Posted on Jan 30, 2008
Anonymous
SOURCE: Problems connecting my Xbox 360 to chair with HMDI
how can i install my guitar and drums for guitar hero 1 can you help me
Posted on Dec 28, 2008
Anonymous
SOURCE: I am Unable to connect my Aduio cables from the xbox 360 to my TV
1) Connect the red, white & yellow audio leads in to the 360 scart adapter and then plug this in to the scart socket on the tv
2) change the xbox 360 selector at the back of the console from HD to TV
2) Select the input of scart on the tv
You should now get pictures & sound.
Posted on Jan 31, 2009
How do I hook up Xbox 360 to this TV? I have no clue where all the plugs go in the back
component leads from xbox to component in on tv
Xbox 360 Component HD AV Cable
http://support.xbox.com/en-AU/xbox-360/system/connect-xbox-360-console-tv
https://www.youtube.com/watch?v=JlE2zHSoQmE
Nov 20, 2015 | Sanyo DS31590 31" TV
One red light on my concel
The Xbox 360 1 red light error is one of the most common problems on the Xbox 360 platform.Basically, the reason the Xbox 360 1 red light occurs is due to DVD or hard drive errors. Whilst these are not as common as graphics card malfunctions (which account for most instances of the "red ring of death" problem)
Therefore, if you have one red light in the power ring of your Xbox 360, you can be confident that this problem is caused by a hard drive error or a DVD problem. The next step in fixing the problem is to determine exactly which component the problem is with, ie whether the error is being caused by a hard drive fault, or whether it is being caused by a DVD drive fault.
To do this you need to consult the error code which appears on your TV screen when you try to turn your console on. If the code displayed is either E67, E69, or E79 then it is a hard drive problem. If it is E64, E65 or E66 then it is a DVD drive problem, which is slightly easier to fix. However, generally both of these errors are remedied by re-attaching the connector leads which can come loose, or by adjusting the "X" clamps on your console's motherboard.
Sep 01, 2009 | Microsoft Xbox 360 Console
Xbox 360 hdtv connection help!!!
Yes, you will need HDTV compatible AV cables.
Jun 25, 2009 | Microsoft Xbox 360 Console
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
New XBOX 360 no picture / sound
ok your lucky, you just need to by a new av cable.. or if that dosnt work you need to get the av caple connection fixed (only about $25)
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
Xbox 360 no picture but sound, works on another HDTV
did you check to see if the av conponent was on tv/hdtv?
Nov 15, 2008 | Microsoft Xbox 360 Console
Hannspree 37" with Xbox 360 HD
Try to use a HDMI cable, your component cables may not be usable with your TV.
Apr 20, 2008 | Hannspree (K206-10U1-005) Television
My xbox 360 keeps on restarting
hit the bution by the on bution and in dack of the controlor
Mar 20, 2008 | Microsoft Xbox 360 Console
Problems with xbox 360 dvd drive
Uhh, did you install your old key on the old dvd drive? You kinda need that. What brand/model is your new internal dvd-drive??
Nov 03, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
145 people viewed this question
Top Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
