Question about LG Refrigerators
My LG Privelege fridge stops working, apparently without cause. If I shake it it will start again. What is wrong and how do I fix it?
Posted by Deborah Miller on
ray gallant
    Top Expert:
  • LG Master
  • 68,332 Answers
SADLY MANY THINGS HAVE NO SELF FIX SHAKING MIGHT INDICATE LOOSE WIRE
Posted on Mar 18, 2019
2 Related Answers
Carmen Mikulic
  • 415 Answers
SOURCE: Fridge not cooling
You most likely have a thermistor that needs replacing. Can you tell me the the temp. in the fridge? Most LG fridges have a 1 year warranty with extended warranty on some parts. If you could provide the model #, I can look into it further for you.
Posted on Feb 03, 2009
lynnh001
  • 474 Answers
SOURCE: My 3.16 03 bmw stopped for no apparent reason.
Check ground wires from body to frame and battery ground. Also check fuel pressure. Could be fuel filter. My sister had same problem and it was fuel filter.
Posted on Jul 23, 2010
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
Control panel on front stops working, only freezer lights are lit, freezer and fridge stop cooling.
when half of the display goes out, it is giving you an error code telling you what is wrong with the fridge.Unplugging it simply resets the computer until the error comes back typically within a few hours.
without knowing what is lit up, it is difficult to help you so I would recommend putting the error code "which bars are lit up" in a comment so we can diagnose further
Feb 03, 2018 | LG LFX25960ST Stainless Steel French Door...
My 3.16 03 bmw stopped for no apparent reason. After the AA checked everything and found nothing wrong the car then started without 'fixing' anything. It stopped again and started after about an hour of...
Jul 23, 2010 | BMW 318 Cars & Trucks
I bought an LG fridge, initially it worked well
U go in firmly demmanding the manager and tell him u want a new refridgerator cause the one u sold me is junk
Oct 31, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Fridge & Freezer not cooling
You will need to change the complete control pc board.
Mar 05, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge not cooling
Feb 03, 2009 | Refrigerators
Please help!!!
If not defrost, could be timer, or heater is not working for some reason. Bad time can cause lots. Compressor could run during defrost, heaters not working, and such. Doubt that the t'stat would be the fix. Could be having a defrost cycle that is too short. Repairing all 3 plus the cost of a tech could get very pricey.
Sep 30, 2008 | Freezers
I am getting an error in my refrigerator (FF error, i think it means freezer fan). The model i have is LRFC22750ST
I am so appauled at the quality, and service of of 2 year old LG fridge with ice despenser, which cost us $3.500. I was so excited to buy a new fridge after 20 years, and now wish I would of kept my old Amana.
After only a month there was a hair line crack in the Chef Fresh draw. I called and left message at LG and no one called me back it was after a month that I finally got someone. Then took another month to get someone to come out....and when a serive man came out he brought me the wrong part. Took another 3 months to reorder right part. Then the same thing happend again to the same drawer ..this time I called LG and asked if there was a recall on a possible manufacturer defect, and they said no and they proceeded to send me another part and the same thing happen I got the wrong part delivered I now have 2 new drawers that are useless because they are for a different model in my possesion. I called Lg to return them and they never came to get them.
And just recently the wheels on the crisper drawers on both sides snapped off, and the crisper lid cover hinges snapped off.
And just today my dials on our fridge are all blank and a ER FF sign has come on. which I have discovered means a Failure in Freezer fan motor., my fridge is not working at the freezer is starting to thaw....great I am dreading calling LG. Here we go again, it will be months before my fridge gets fixed.
I will never buy another LG product again.
Jul 18, 2008 | LG Refrigerators
Refrigerators Logo
50 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
