Question about Jensen Car Audio & Video
I have a jensen mcd 5110 in a boat and it will not power up have looked at fuses and no luck
Posted by Tim Bookmiller on
STEVE
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Jensen Master
  • 35,270 Answers
Have you got power at the radio?
Posted on Mar 17, 2019
3 Related Answers
Benny333
SOURCE: Need a replacement faceplate for my mcd5110 jensen AM/FM CD player
I have the whole radio whithout a wire harness give me 50.00 and you will have a replacement radio in the future
Posted on Feb 19, 2008
natenash7986
nate dogg
  • 53 Answers
SOURCE: I have a model Jensen
the unit is shot there is no hope for it. i have seen this problem many times in boats and never been able to fix the problem. i have had customers send the unit back to jensen and received a new one but check and see if your 1 yr guarantee is still good.
Posted on Aug 07, 2008
Anonymous
SOURCE: Can I buy the face only to the jensen marine mcd 5110
Do you still need the face plate for a 5110? I have one with case. if so e-mail me @ [email protected]
Posted on Jan 01, 2009
My Jensen MCD 5110 Marine radio acts like the antenna is unplugged. I can't figure out how to remove the radio from it's sleeve to re-plug the antenna jack (if that is the problem)
I don't know much about marine radios. I am a ham radio operator, but they are much the same, if you do not hear any static (with squelch control turned down), then I suspect you are correct about the antenna. It could be the antenna itself, or the coax line to it, or the connection point at the radio or at the antenna. You're stuck without being able to remove it. If you do and find nothing at the radio, you'll need to check the connection at the antenna etc. Good luck.
Nov 21, 2014 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
Need to know what order to hook up red,yellow,and black wire which to positive which to neg and what size inline fuse is needed for my mcd 5080
Red- power Yellow-Memory Black-Ground
Unless the yellow wire has a fuse built into it then....
Yellow- Power Red-Acc/Ign Black- Ground
If the fuse you are asking about is on the radio t s usually a 10 or 15 amp fuse but if you mean for the power wire for a amp then it depends on the power amount of the amp....look on the amp and find the sum of the fuses on the amp and use a inline fuse that is the next fuse size sum...
Ex. 2 40 watt fuses on the amp then 40+40=80 watts so you would want to get a 100 watt fuse. Also remember you can never go to big for your inline fuse with a amp
Aug 22, 2011 | Jensen Car Audio & Video
Does the small jensen power button light stay on all the time?I installed it on a boat, the dim blue light its lit all the time!
Yes it does. I installed the same unit on my boat and ran an inline switch to the battery to turn it off so as to not wear the battery down.
Jul 16, 2009 | Jensen CD-3010 X CD Player
Amplifier and sub installation in a boat.
norally grounding them in the same place is ok but it could just theres not enough power from the amp too power two subs try hooking up one and see if that gives you the sound your looking for
Jul 09, 2009 | Car Audio & Video
Wire conection problem-no manual
Black is obviously ground. red is for switched power (only has power when vehicle is on) single yellow or orange is constant power Dual grey and dual white (solid grey/grey with black) and dual etc. are for speakers. the blue is for accessory power for amps and eq's. on the speaker wires the one with markings is for + and the soild is for -.
May 16, 2009 | Jensen MCD-9424RC CD Player
Nov 29, 2008 | Jensen MSR4050G CD Player
I have a model Jensen MCD 5110 and the face plate keeps flashing and all the stations look like they are searching for a channel..The other problem is the volume won't go past number 12 out of 46 and I can...
Aug 07, 2008 | Jensen Car Audio & Video
Car Audio & Video Logo
50 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Muntejaya Ginting
Muntejaya Ginting
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
