Question about Cycling
Can any one of your products be used to power a motorbike trickle charger that uses a uk 3 pin plug ?
Posted by Joe Jefferson on
5 Related Answers
Anonymous
SOURCE: Re: hannspree 37 inch
i have got a humax 32"lcd idtv.
my sky remote does not find it can i get a code to put in thank"s
Posted on Jun 07, 2008
Anonymous
  • 367 Answers
SOURCE: Nintendo DS Lite Purchased in the USA
Remove battery clean contacts on battery and game using pencil eraser. Then try charging. Or replace the battery
Posted on Jan 19, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: convert 2 pin dewalt charger to 3 pin how
By 3 pin do you mean the third pin being a ground. If so that charger does not have anything internal to ground to. It is a 120Volt Double insulated tool. Let me know if you are trying to do something different.
Posted on Jan 29, 2009
Anonymous
  • 127 Answers
SOURCE: sx700 charger
try useing phone charger as long as jack will fit yours
Posted on Jul 16, 2009
emissionwiz
Marvin
  • 85239 Answers
SOURCE: charging the battery
The slower you charge the battery the better it is for the battery life. If the battery went dead and there doesn't seem to be any reason have a local parts store load test it, it may have a dead or shorted cell and need to be replaced. The testing is free at Autozone and others like them. Please rate my help for Fixya. Thanks
Posted on Jan 19, 2012
I have bought a Braun epilator 7 , Braun type:5377 , in USA and have purchased the charger in the UK which is 100-240 v , do I still need to get a voltage converter to be able to use it in the UK ?
If the charger is 100 to 240VAC, it should work. USA use 110 volt so the charger should be OK with 240. The UK charger will probably have a UK 3 pin plug on it. If you use it in the US, you will have to change the plug again or buy an international adaptor which can be adapted to fit most outlets anywhere in the World.
Apr 19, 2015 | Braun Health & Beauty
How do i change my wiring for my autogo 550 to adapt it to a trickle charger. it now has 4 wires , I need 2 wires?
this scooter uses lead acid batteries
this type of battery much like a car type
uses constant voltage
like 13,8v from a car alternator
so a trickle charger is no use and wont work
as it only provides a constant current and not a constant voltage type senario for the charge up
use a car battery charger
problem solved for about a fiver....
the scooter will need eather 12v or 24volts
so you need either a car charger or a truck battery charger
at least 15 amp @ 13.8volts...
Sep 14, 2014 | Radio Communications
How long will batteries last if not used?
Get the batteries tested .As a motor mechanic your husband should know about battery care you could have removed them and charged them with a car battery charger or any of the trickle chargers used to keep batteries charged while not in use
May 09, 2017 | Pride Mobility Products Sonic Scooter By...
I bought an MPV5 used. Batteries won't charge. Charger light is green after 24 hours...slight power surge then dies. The seller said it hadn't been plugged in for a long time. I also noticed the batteries...
Lets solve this, one question at a time ....
First your batteries are not charging,This may be because of it siting for too long without a charge.The batteries may be so dead that your charger cannot reconize them. dont losse hope there are ways to check your batteries and charger with out spending alot of money on a tech coming over.
1) Unplug and remove your batteries from the chair
2) Find your self a charge that trickle charge
(Note: If you have a batterie charger ,trickle charge is the lowest set charge)
3) Trickle charge each batterie to about 50%
4) Install batteries back on to chair
5) Plug in chair charger
The chairs charger should come on ,and that right there tells you that you have a good charger!
The batteries that came with this chair are not bad and are considered ok to use .These type of batteries are what you call maintenance batteries ,which your always having to check if the leaking or need water.The gell type batteries are what they call non-maintenance.That you dont have to always look after but are more money.Thats why they recommend the gells so that the user doesn't have to work on there chair.
I hope that was helpful ,Happy Riding
Feb 10, 2011 | NRS Hoveround MPV 5 - Used Power...
I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE JET 3 Ultra Power Chair Smart Battery Charger, CAN WE USE A COMPUTER CABLE INSTEAD IF NOT WHAT CAN WE DO.
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Nov 25, 2010 | Pride Mobility Products New Pride Mobility...
Where can i buy batteries and a charger for my dynamic d90
Jegs11 Keynexions on eBay UK has mains-adaptors and car power-leads for The Dynamik D90S (gas-powered nail-gun); EU 2-pin, US/CA 2-pin, AU/NZ 2-pin, UK/IE 3-pin, as well as the universal car cable. They do NOT stock the actual charger-base though...:
http://stores.ebay.co.uk/Jegs11-Keynexions/_i.html?_nkw=d90s&submit=Search&_sid=58583447
Aug 21, 2010 | Dynamic Arrow Fastener Co. T50PBN Staple &...
Engine wont turn over at start
Hi, Do you have an alarm & Immobiliser fitted on your bike as these drain the battery on your bike very quickly? If so i would recommend removing your battery and fully charging it with a decent amp-age charger. If you have your garage attached to your house then i would definitely recommend purchasing a trickle charger and when not using your bike keep this plugged into the mains and you should not have this problem again. all motorbike shops sell these chargers If after this the battery goes flat again i would suggest purchasing a new battery. This is a common fault as most motorbikes sit in the garage through the winter months and if not kept on charge will deteriorate. Hope this helps.
Apr 09, 2010 | 2006 Yamaha V Star 1100 Custom
Dell latitude d600 purchased in USA WHAT do i need to make it work in UK POWER PLUG NOT AS IN UK thank you
if its a round 3 pin and it plugs into a power unit 3 spade type plug end, using a plug like the one that goes into an electic kettle, just buy a kettle lead and use that.
If the power unit itself is not 240 volt you can buy a universal charger/power unit from maplins or similair, but check the wattage
http://www.maplin.co.uk/Search.aspx?criteria=laptop%20power&source=15&SD=Y
Aug 23, 2008 | Computers & Internet
Cycling Logo
180 people viewed this question
Top Cycling Experts
Marvin
Marvin
MODERATOR Canada
MODERATOR Canada
Tom Chichester
Are you a Cycling Expert? Answer questions, earn points and help others
