Question about Nitro BMW-484 Car Amp
BMW 318i oil
Hi...... i have a BMW model 318i year 1993 ,i don't know how much oil may i put in?
Posted by daban_ata on
taran_2005
  • 10,515 Answers
Around 4 litres.
Thanks.
Posted on Aug 06, 2009
Hi I have a 1994 318i BMW Automatic, there sims 2 be problem with shifting from 3 rd to 4 th gear and slipping with that, but if I put it in manual mode than I lose a 4 th gear all 2gether, and the
Hi there.
Well because its a auto box you could have a band or pump problem which is in the gear box and is bathed in auto matic fluid oil and that could be your problem as the bands do wear down fast on a lot of cars and BMW with there power that could be you.
So take it to a auto box people and get it checked out.
Jul 11, 2014 | 1998 BMW 318i Automatic
A red warning light comes on when I drive my BMW 318i dolphin.
Please refer to the owners manual for red light warning, it can be low oil pressure or hot engine or emissions system. If you don't have an owqners manual you can find used ones on eBay Motors.
Aug 06, 2012 | BMW 318i Cars & Trucks
Hi i have a 318i bmw 2001 my fuel consumption is
Last month, my wife complained of high gas usage as well. I suddenly remembered that I had forgotten to change the air filter the last time I did the oil change. It had been over 5 months since I'd put a new one in. So, we got a new air filter, and monitored the usage, and it was back to normal again. Maybe try this?
Dec 01, 2010 | 2000 BMW 3 Series
Just want to find out...does bmw 318i e36 have a timing belt or timing chain?
There are 2 engines used on the 318i. One has a chain the other a belt. The M40B18(1990-1993) uses a cam belt and the M43B18(1993-1998) a chain.
Nov 01, 2010 | BMW 318 Cars & Trucks
All my electonic windows on my 1993 bmw 318i wont work at all, they dont go up or down either does my sunroof..
Fuse number 14(30 amp) under the hood. A likely start. If you need the official shop manual, let me know.
Aug 11, 2010 | 1993 BMW 3 Series
I don't know what oil to use for my BMW 318i
BMW recommends 15W-40. However your driving style can vary what you should use.. Colder climates thinner is better, city driving slightly thicker can be helpful.
I use 20W-50 year round here in PA in my ti without any issues.
Jul 09, 2009 | 1997 BMW 318
I would like to know how to reset the oil change indicator on a 1994 BMW 318i
Switch on ignition.
Earth terminal 7 (I've no pic sorry) and hold for 3 seconds.
Switch ignition off
That should do it
Apr 28, 2009 | BMW 318 Cars & Trucks
Battery or radiator light on a 1999 BMW 318i SE
The below is taken from another site written a year ago:
What you are looking at is the Service Indicator. The green, yellow and red lights let you know when service needs to be performed. The green lights mean everything is still good. The yellow lights mean "anytime you're ready." The red lights mean do the service ASAP. There are also two other lighted areas. One says "inspection," the other says "oil change" (or oil service.) An oil change is an oil change. However, there are two inspections: Inspection 1 is normally at every other 15,000 miles; Inspections 2 is at every 30,000 miles. Your local BMW dealer should have a pamphlet listing all duties performed for each of the services. Inspection 2 can run you around $400-$800 depending on the service station/dealership's labor rates. Inspections 1 should be around 1/2 of that. You should have your oil changed about every 5000 miles. Dealership oil changes can range from $35-$65. A BMW that is well taken care of will last a long time.
FYI, don't be surprised if the SI (service indicator) board decides to **** out one day. I'm surprised to see yours is still working (they usually die within 10 years unless someone went thru the expense to have it replaced.) If/when it does go, just gauge your services by the mileage intervals I've listed above. I'd also recommend when you stop into (or just call) the dealership, go to the parts department and order an owner's manual for your BMW. Should be less than $20 and get to you in about a week unless they have one in stock.
When the service tech has performed the necessary service(s), he will reset your SI board so that only green lights are showing.
  • 1 year ago
Dec 09, 2008 | 1999 BMW 318 ti
BMW
hi
whats the problem with the car?
steering being light is not a fault.
thank you
Sep 30, 2017 | 1996 BMW 318
Nitro BMW-484 Car Amp Logo
177 people viewed this question
Top Nitro Car Audio & Video Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
STEVE SPAM REMOVER
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
