Question about Refrigerators
Ice maker mot filling with water
I stalled new ice maker water flows to dispenser mone to ice tray
Posted by Woodie Thompspn on
Doug
    Habit-Forming:
    Scholar:
  • 99 Answers
Have you reset the icemaker? Usually there's a lever or switch that you have press to reset it. You did not post the make/model of your fridge so it's difficult to say which reset device you have.
Posted on Mar 17, 2019
RAMON
    New Friend:
    Problem Solver:
  • 6 Answers
There is a water control valve that controls where the water goes after it's hooked up to the supply line behind the refrigerator. This valve has a solenoid on each output, one to water dispenser, one to icemaker. It sounds like the solenoid that controls the icemaker water supply is bad (not uncommon). You need to replace the valve (around $80).
Posted on Mar 18, 2019
5 Related Answers
willis43
SOURCE: Water doesnt stop after ice tray is filled
My amana sxd25s2w side by side, water dispener just stopped working all at once. I hear a click when pushing the bar, and the light goes on but no water. Also the ice maker is over flowing when it fills the tray. Are these 2 things related and I would like to replace the filter for the water , where can I find that. Please help!
Posted on May 04, 2008
docjohn174
john gagnon
  • 943 Answers
SOURCE: Kenmore Ice Maker Problem, Side by Side Refrigerator
Thanks for the question There is a water valve just for the ice maker so the problem could be there if you have a volt meter you can check the valve what you can do to check the valve reverse the wires onthe valve and push your water dispenser if no water goes into your ice maker . you have a bad valve replace thanks for the question The appliance doc
Posted on Sep 11, 2008
Anonymous
SOURCE: Samsung RS21DCNS: Ice maker fills up but water dispenser does not dispense water
the fridge is making a noise , sounds like a fan catching and the water will not flow
the firdge is a Samsung RS21DCNS 19.6CF
Posted on Nov 09, 2008
Anonymous
  • 15 Answers
SOURCE: Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Posted on Jul 24, 2009
Anonymous
  • 64 Answers
SOURCE: ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Posted on Aug 26, 2009
My Bosch ice maker has a problem. It has frozen over and does not dispense the ice cubes, the refrigerator thinks it has dispensed the cubes and so try's to fill the ice cube tray up again with wa
Ice makers have heaters that loosen the cubes when time for harvest. Sounds like the heater on yours is bad, or maybe the ice maker itself is just bad. Most likely will have to replace ice maker.
Oct 12, 2017 | Bosch Refrigerators
I have a kitchenaid 23cd.Icemaker doesn't work has 40# water pressure 5 deg in freezer water works to fill glass no water in ice tray unpluged for 24 hours
If the water dispenser is working and fill glass function is working but the ice maker section there is no water in the tray then its faulty ice maker valve.This is a twin valve.The valve is one unit,but has two sections one for water and one for ice dispenser.This valve is got faulty and not working for both sections so water is not entering the ice maker tray.
There is a water valve at the back of the ice maker.This valve controls the flow of water in the ice maker chamber.If this valve is not functioning as required then water will not enter the ice maker.This valve is at the back of ice maker connected to the water fill tube.It has to be replaced to clear this problem.
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Feb 01, 2011 | Refrigerators
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
Ice maker is not making ice
Even though the water dispenser is OK you need to make sure the tray(s) in the ice maker are filling. The filter valve, located to the rear of the ice maker can freeze over and stop water flow. Check the supply line for the ice maker, it may be separate from the water dispenser.
Mar 24, 2010 | KitchenAid Superba Architect KSCS25INSS...
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Brand new ice maker, water fill to tray will not shut off
The new ice maker should tell the dual water valve on rear of refrigerator to turn on if the tray makes a complete cycle. So the new ice maker is defective or the water valve on back is stuck open that leads up to the ice maker. Unplug the wires to the water control valve on back of the refrigerator and then turn the ice maker on. If the water continues to flow I recommend replacing the water valve. If the water stops coming to the ice maker I recommend returning the new ice maker. You only need to unplug the side of the water control valve leading to the ice make. I also recommend a pre-filter for the incoming water before the water control valve. Makes the water and ice better and keeps trash from damaging the water control valve. Let me know your results or if you need more assistance, Thanks, Sea Breeze
Jul 14, 2009 | Whirlpool ET8WTKXK Top Freezer...
Oct 04, 2008 | Refrigerators
Oct 23, 2007 | Kenmore 53603 / 53606 Stainless Steel Side...
Refrigerators Logo
523 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
