I have 3com 4400 superstack. i cant log in and dont have any password becouse old staff already resign
Posted by mdhassanaim on
Anonymous
    Scholar:
  • 101 Answers
Try this link. 3Com
3Com website is still active for support.
Good Luck
Posted on Aug 19, 2009
Switch powers off
  1. Faulty power supply
  2. Heat issue
See if there are any logs on the switch that you can check for errors. If you can't I suggest you call 3Com for troubleshooting.
Oct 10, 2013 | 3Com SuperStack 3 3870 48-Port...
I want to know the default ip address of 3com superstack 3 switch 4500 model and the default username and password of the device
Username:monitor Password: monitor---monitor mode, view only manager manager--can change all except security features admin (no password)--sets security features IP: 169.254.100.100 or 169.254.100.99
Jul 18, 2011 | 3Com 4500 24-Port Ethernet Switch
How to rest t
Connect the switch with a null-modem cable
In windows, hyperterminal , To enter into Password Recovery Mode:
login: recover
password: recover
Turn the power off (hard reset) within 30seconds
Re-enter the password twice.
Feb 23, 2011 | 3Com SuperStack 3 4228G (3C17304-US)...
How to recover old password on 4300 switch?
you manually RESET your device by pressing the "reset" button at the back. it will be reset to factory setting with the default password loaded.
Regards!
Jul 13, 2009 | 3Com 3C17100 /RETAIL3COM SUPERSTACK III...
Routing problem
The last part of the IP address has to be more than 10 apart. That is to say: if your first address is 193.156.36.90 then your second should be 193.156.36.100 or higher or 193.156.36.80 or lower. I like to go for 50 higher or lower then you are well out of the range of your main router.
May 27, 2009 | 3Com SuperStack II NETBuilder 222 Access...
Inherited 2 switches 3com 4228g (3c17403) password problem
I haven't worked with these switches but generally settings such as ip address and factory defaults can be set through the Console Interface (CLI). You will need a null-modem cable to access this and a terminal client (Windows Hyperterminal works).
Hope that helps
Dec 31, 2008 | 3Com SuperStack 3 4228G (3C17304-US)...
Doesn't POST
I've got a Superstack II 3300 24port switch, all leds are on, and led 8 blinks.
I'll let you know if I find a solution.
Dec 09, 2008 | 3Com SuperStack 3 3300 TM Networking...
3COM network switch access problem
You Could check to see if it has a passowrd and username as 3com or user as username or password thats wat mine is and i forget my pass
Aug 04, 2008 | 3Com SuperStack 3 4924 Networking Switch
Problem with SW 4400 - restarting....
switch dont restart by themselves without command, first remove the switch from the network, disconnect from internet, make sure you hadn't fired anybody recently it sounds like a hack. reduce network traffic to local area only and priortise important internet traffic. now got back to the switch and troubleshoot make to check the reboot command on error or when error is found, if the problem stops when the switch is remove somebody is messing with the network.or the darn switch is faulty install a new one.
May 30, 2008 | 3Com SuperStack 3 4400 (3C17204-US)...
Computers & Internet Logo
350 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
