Bad or very low battery
Replace at Garmin
But first know this:
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Sounds like a bad or low battery. Do you have the Garmin
approved charger / car charger?? You may have to send your 265 in for battery
replacement or try this:
There are three ways to charge the internal battery in your automotive GPS
unit.1
1 - Please note
that temperature can play an effect on the charging of a device. If the battery
registers a temperature of 0°C and below or 45°C and above (32°F and 113°F
respectively) then it will not charge. When connected to external power it will
only be operating off of external power.
2 - The Quest® and Quest® 2 will not charge using a
USB cable.
SOURCE: restore garmin nuvi 265w
Do a MASTER RESET for that.
Normal
0
false
false
false
font-size:10.0pt;
To perform a Master Reset on the nuvi 200, 205, 465, 500, 600,
700, 705, 1200,1300,1400 or 1600 series device:
Note: A master reset
will erase all waypoints or favorites and will restore your unit to the default
factory settings. But who cares if you have problems, right?
The device will automatically reset. Follow the on screen prompts then place
your device in an area with a clear view of the sky until it acquires
satellites.
SOURCE: Garmin Nuvi 265W, T, or WT
W = wide screen version, 4.3" diagonal screen GPS
T = Includes Traffic receiver
WT = widescreen & with traffic receiver
If I answered your question, please rate my solution as fixya.
Thanks
- Jim
SHARCNET-USA
SOURCE: my Garmin Nuvi 265W will not turn on
plug it in to the computer for a few hours, then hold the power switch to the on position for up to 15 seconds.
if that fails, disconnect it from the power source, then press and hold
the lower right corner of the screen, while holding the lower right
corner, switch the power to the on position. once you see the message
"do you really want to delete your data" select yes, then follow the on screen instructions
bill
SOURCE: my garmin nuvi 265w starts
If your device is currently experiencing the following symptoms it may need to come in for service/repair:
For service/repair of a device due to the three symptoms listed above please select "No - I would like to submit a follow up email" below this article. You will be taken to an email form that you can submit to obtain a Return Material Authorization number.
Please note: It is important to completely fill out the form with as much information as possible including:
