SOURCE: maxent lcd
Your TV is an "HD-Ready" television. What this means is that your TV is ready to accept HD input from an outside source, but doesn't have the ability to produce the content itself. It is a monitor and does not have a digital tuner. Without a digital tuner (or for cable a QAM tuner) you will not receive OTA broadcast HD.
You need to purchase a High Definition capable set-top converter box. The converter box will have HD component out and may have HDMI out, either will feed your HD Ready TV.
SOURCE: proron pltv-4250 no signal
THE BEST INPUT ON YOUR SET IS THE HDMI INPUT.2ND THE COMPOSITE INPUT. 3RD THE COMPONENT INPUT. AND 4TH THE ANTENNA INPUT. MOST DISH BOXES HAVE AT LEAST THE COMPONENT OUTPUT. YELLOW IS THE VIDEO AND RED AND WHITE FOR AUDIO. USE RCA CABLES TO GO FROM BOX TO LCD SET. ON THE DISH BOX YOU CAN GO FROM ANTENNA OUT TO THE CABLE OR ANTENNA IN ON THE LCD. SWITCH TV TO CHANNEL 3. AND TURN YOUR DISH BOX ON.
SOURCE: maxent plasma tv is showing only vertical lines.
Common problem on these sets are many many bad caps on the digital board. Repair kits are available for these containing the necessary parts if you're savvy with a soldering iron. Otherwise, replacement of the digital board is necessary and you'll have to contact either Maxent or a local repair shop. Tracking down which caps are bad can be difficult even with the right equipment as some tend to check good while in circuit when they are actually bad.
SOURCE: how do i hook regular cable to Maxent MX-42EPM20 42 in. EDTV Plasma Television
Your Maxent MX-42EPM20 is not a TV (Television) it is a Plasma panel. The difference being your Panel does not a TV Tuner (no Coax jack or electronics relating to a tuner) Below is the spec sheet that shows this
http://reviews.cnet.com/flat-panel-tvs/maxent-mx-42epm20/4507-6482_7-32139310.html?tag=mncol;subnav
You can use a cable box or a cheap Digital TV receiver. You can buy them at walmart, You need one with A/V out puts such as Component. Here is a link to one. This will give you a tuner.
http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
SOURCE: Unable to connect to roku please try again later.. is the message on the tv screen
I would disconnect the power going to the Roku Stick, wait at least a minute or so, reconnect the stick to the power supply. If this does not work contract customer support at this link: Contact Support
I just started 6 weeks ago and I've gotten 2 check for a total of $2,200...this is the best decision I made in a long time! "Thank you for giving me this extraordinary opportunity to make extra money from home. This extra cash has changed my life in so many ways, thank you!"
Visit sitehttp://Theprocoin.com
