Question about Smith Corona Office Equipment & Supplies
My Smith Corona SL500 will not type the correct letters. If I type a "J", I get a "?". What is wrong with it?
Posted by Billie Laird on
James Keysor
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Most likely bad printwheel, spokes may be catching on the ribbon and not going to home position. Try a new wheel, and or make sure carrier is returning to home position every time. make with white out the top of the print wheel spoke at home position and make sure it always comes back to that spot when you turn machine on and off and on. This will tell you if the machine is starting in the same place every time.
Posted on Mar 25, 2019
5 Related Answers
JUSTOLDJIM
James Cagle
  • 482 Answers
SOURCE: fitting new ribbons to smith corona 100 electric typewriter
the lift of tape has a dull side and a bright side make sure the dull side is toward the paper then press and hold the code key and the = key to reset the typewriter also see page 6 in the owners manual
Posted on Oct 29, 2007
Anonymous
  • 328 Answers
SOURCE: smiths corona SL500
Ebay. Smithcorona.com
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Dec 30, 2007
Anonymous
SOURCE: Smith Corona 3L (old one)
I agree with JUSTOLDJIM. I recently found a 3L near the dumpster at my townhome. I took it in a looked at it. There is a black and white ribbon used for typing and erasure of ink.
As far as the TAB goes, I haven't used them yet.
Posted on Jan 06, 2009
Anonymous
  • 45 Answers
SOURCE: Need owners manual:
I have been unable to find a site where you can download a Smith Corona typewriter manual. However, you can try going to Will Repair Service. They carry manuals of every Smith Corona typewriter ever made, and you should be able to find a manual for your particular typewriter there. I find them to be a very helpful and trustworthy typewriter shop.
YES, SMITH CORONA DOES STILL EXIST!
Best of luck to you! :-)
Posted on Jun 07, 2009
Anonymous
SOURCE: lost manual for Smith Corona sl 575 spell right typewriter
how do I replace the correcting tape in my Smith Corona Spell Write XD6600?
Posted on Dec 07, 2010
How do we use the correction on a smith corona sl 470
Provided that you have a fresh correctable ribbon and lift off and they are properly installed type a letter, press correction key the correction should take place.
DickyO
May 21, 2012 | Smith Corona Typewriter SL470 Refurbished...
How to correctly install the correction tape in a smith corona electric typewriter SD770
you have to turn the spool with the knob untill there is tension on the tape or it won't stay in place
Nov 08, 2011 | Smith Corona Wordsmith 100 Typewriter
My smith corona model ka11 is typing symbols instead of the letters. Can you help me get this corrected?
Printwheel in wrong. release the printwheel, make sure the pin is aligned with the slot on the hub and snap it back in. The printwheel should spin, then home out to the left margin, then it should be ok. If not try it again.Check to make sure no pedals on the printwheel are bent.
Hopes this helps!
Feb 10, 2011 | Smith Corona Wordsmith 100 Typewriter
Smith Corona 300 DLE--toggle from italics to normal type
To switch fonts on this typewriter, you need to change the letter wheel. Unfortunately, there is no practical way to change the letter wheel in the middle of a document.
Apr 10, 2009 | Smith Corona Office Equipment & Supplies
Smiths corona SL500
Nov 14, 2007 | Smith Corona Wordsmith 200 Typewriter
Types wrong Characters
Does it always type the same wrong letter ie a always prints u or w ? if so the print wheel drive gear is out of position. if not and it get random letters some thing may be interfering with the wheel rotation.
Jul 04, 2007 | Smith Corona Wordsmith 200 Typewriter
85 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Ekse
James Keysor
Level 1 Expert
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
