Question about Sharp Aquos Televison & Video
I have a sharp Aquos lc-50ub30u and the Screen is black. Tried soft reset, still not working. The light on the tv powers on but not image on the screen.
We took the back off and found on the power supply board, a brown spot near the top capacitor looks. After removing the board, it appears the mosfet mdd7n20c has fried. Will any 200v 5a mosfet be able to replace it? Or do I need to find a magnachip replacement?
Posted by Joshua Speer on
5 Related Answers
Anonymous
  • 53 Answers
SOURCE: No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Posted on Mar 16, 2008
Anonymous
SOURCE: Sharp Aquos LC-C3242U LCD screen go's black after power on.
I have (had) the exact same problem with my Sharp LC40C32U. I purchased it at CostCo 1 1/2 years ago. Because they changed their return policy I thought I was out almost a $1,000 but decided to ask them if they could do anything. Wouldn't you know they had an extended warranty that was still in affect. I called their service people and spent over an hour on the phone with them. After going through all the troubleshooting steps they arraigned for an in home repair (free of charge).The technician that came new exactly what the problem was and how to fix it. The kicker is no parts were bad, over time the 2 grounding points on one circuit board were not making contact correctly. He explained that the problem would be worse when the set was cold, as it heated up the grounding points would make a better contact. That's why it seemed to occur everyday first thing in the morning. He took the back off, removed the circuit board and cleaned the contacts. When he put it back together he tightened the screws down fairly tight, explaining that the factory does not tighten them enough which is why I (we) have the problem in the first place. This took all of about 20 minutes. I have not had any problems since. If you live in San Diego, CA the company that fix'ed my Sharp is Advanced Electronic Service.
Posted on Aug 29, 2008
Wondra
SOURCE: Power Supply Burnout
Apparently there was a problem with some of the capacitors in these models. Your capacitor definitely is popped.
I had the same problem. The fuse was okay, but two capacitors were blown. One was at location C23 and I think the other at C17. I took it to a local electronics shop and they replaced and soldered the new capacitors on for me. It only cost $16.22. They were a 3300 µF and a 1000 µF.
Check out this information on this site as well.
http://forum.videohelp.com/topic340925.html
Posted on Nov 11, 2008
Jim Krause
  • 1779 Answers
SOURCE: power supply bad on Sharp Aquos LC - bad board - schematic to ID?
Buy the green light going on means Standby is ok. Next, would be to locate the plug coming from the main board to the power supply and find the post that says PO which means power on. With your meter on that post, press the power button as see if the reading goes High, if it does then the main board is able to turn on the power supply. Next, find the plug on the power supply that goes to the inverter( the long board on the side) remove it and see if you have 24 volts coming out of the power supply when you press the power. If you do, then the inverter board is bad, if you don't have 24 v, then the power supply is bad. There are NO diagrams available for these set other than a flow chart if you can find one. A regular svc tech does'nt need a manual for these anyway.
Let me know how you do Kathy ?
Posted on May 17, 2009
decarpentier
SOURCE: sharp aquos model LC-32D40U screen goes black
The Sharp TV model LC32D40U / 41U "Black Screen problem" is a very well known issue. The inverter is losing ground contact which will prevent the back-light from staying on. The solution is to re-tighten six screws on the inverter board. You also would want to clean the copper contacts on then bottom of the inverter where the screws go through. Access to the inverter board will require some disassembly. Plan on taking at least three hours to repair. See the photo for the location of the screws. Use some "blue" locktight" on these six screws. There is actually a Sharp Technical Service Bulletin that describes these screws. Sharp wants you to replace these screws with a newer version. They cost at least $2.50 each! I think my method will work just as good using the "Locktight"_548.jpg_547.jpg
Posted on Jan 24, 2011
1helpful
Sharp Aquos Smart tv flipped screen
Hello Danny,
Have you tried resetting the TV to factory settings?
I would suggest to try that and see if it works..
Good Luck
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
Brand new TV, spotty HDMI functionality (sometimes recognizes cable box or comupter, but not always). Attempted firmware update on a Sharp Aquos LC-32SH7E (European model). Don't think it ever...
Did you go through the entire factory reset? When you plugged in the power cord did you continue to hold the volume - and input button until the television powered on and a K appeared on the screen never releasing at all?
Force the tv on by holding down channel down and volume + on the tv while plugging the tv in. See if the tv still lights up and if you get audio.
SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
6helpful
2answers
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Televison & Video Logo
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
