Question about Locks & Locksmithing
How I can change the cleaning brush fo an Ilco 040 Hd authomatic
Posted by Quiber Palma on
Chris Walker
    Top Expert:
  • Locks & Lock... Master
  • 1,551 Answers
Posted on Mar 20, 2019
Wat is the spark plug gap fo 50hp mercury two stoke 2009
The plug gap is most likely .040, however can you please confirm your serial number?
Sep 10, 2014 | Mercury Force Tilt Trim Motor, 25-50 HP...
How to install bios
the bios is already on the board,
when you are booting the computer you have to push down on the F10, if that doesnt work than try F1 and thanF2, every time you try to enter the motherboard bios you have to start from a cold boot.
website for motherboard bios configuration and settings is at
http://www.msicomputer.com
if you want a copy of the bios setup and configurations and everything explained in detail go to your browser and type the following information.
MS-6758-040 BIOS MANUAL OR
MSI MS-6758-040 BIOS MANAUL
the bois controls everything the that runs you computer, video, ram, HD, CPU, PORT FUNCTIONS, BOOT SEQUENCE, SMART FAN CONFIGURATION, HD CONFIGURATION, TEMP. SETTINGS, AND ALOT MORE STUFF AND VERY LONG LIST.
MAKE SURE THE BATTERY IS MIN. 3VOLTS
Jun 25, 2014 | MSI MS-6758-040 Motherboard
How can i remove a unican lock
You will find installation manuals on this page:
http://www.kaba-ilco.com/kaba-access-control/Documentation-Support/292720/simplex-mechanical-pushbutton-locks.html
You may need to install Adobe reader if you cannot view the documents. There is a "Get Adobe Reader" link found just above the chart if you can't.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Oct 04, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
Code dont work,key rod dont seem to work,cant change code.
Yours is an unusual problem. Therefore, I suggest that you call Kaba Ilco during regular business hours for assistance. Toll free: 800-849-8324 Be sure to have the model number and any other pertinent info on your lock ready if you call.
On the net:
1-800-849-8324 (option 3, and then option 6)
Good luck--and please provide feedback if this helps!
Aug 11, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I have a 5 button simplex lock with a arm bar opening lever inside the door. how do I change the combo?
I can't help you directly, but I will steer you to further information.
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
May 09, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
The carpet brush won't revolve on the Hoover S3765. After 5 months I replaced the belt and the salesman gave us model 38528-036. Is this correct? The rotating brushes are not hard to turn; it's just...
this is the part for the belt, 38528036. you can get it at sears website or service center. also make sure you clean the caps on the side of the brush. take them out and remove hair and dirt. put a little or mineral oil and install them back.
good luck to you.
Feb 08, 2011 | Hoover S3765-040 WindTunnel Bagless...
Bought a house with a Unican 7000 series keyless lock on it. I have the current code but want to change it. Can someone tell me how I can change the code?
Yow will find a link to download the manual for your model on this page:
Oct 30, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Need to removed from door to change door slab?
Oct 06, 2010 | Simplex Kaba Ilco Unican LP1000...
Locks & Locksmithing Logo
162 people viewed this question
Top Locks & Locksmithing Experts
john h
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
