Question about Karcher Garden
Where do you check the oil level on a Karcher KB2020
Posted by Colin Wright on
Kardoc
    Top Expert:
  • Karcher Master
  • 5,602 Answers
I have a karcher high pressure washer model hd 2500 hk. What would make my unit stop running after about 45 seconds ,running at full throttle and at high pressure
There could be two possible causes for your problem, one is oil level in the engine could be low, or the engine is tilted or not positioned on a level ground, and the second one is water in the carburetor. Check the oil level and replace the oil if necessary, drain the fuel from the fuel tank and the carburetor and clean the carburetor ports and jets, check the fuel for contamination, check and replace or clean the spark plug if necessary, check if the air filter is blocked, dirty, carbonated, or saturated with oil, and replace if necessary.
Jul 30, 2014 | Karcher 2500 PSI Pressure Washer
Yes it is not an engine problem it is the high pressure pump that stopped working as I was power washing
May 27, 2014 | Karcher 2500 PSI Pressure Washer
Engine off while running
check oil level or oil pressure switch ( disconnect switch while testing for function )
Dec 30, 2013 | Karcher 2500 PSI Pressure Washer
Ihave a karcher 630m which keeps cutting out please can you help
OIL LEVEL LOW?, CARB NEEDS CLEANED, DRAIN CARB FUEL BOWL CHECK COLOR OF GAS , MAY HAVE WATER OR OLD GAS IN BOWL AS WELL,
Mar 25, 2011 | Karcher Garden
What type of fuel is to be used? oil/gas mixed? pls advise
Check to see whether 4 stroke is written on engine. If this is the case, regular gas can be used.
Feb 19, 2011 | Karcher 2500 PSI Pressure Washer
Press. Washer Honda engine gx 390 will not start
did you leave fuel in it from last year, if so remove all fuel from tank, drain carb. (remove float bowl if it doesn't have a drain bolt) put in fresh fuel, check your oil level and you should be good to go. if not, please take it to a qualified tech. for carb. cleaning.
Doc
May 17, 2010 | Karcher G3025OH Pressure Washer
I have a karcher power washer model 2400 how much oil should i put in it?
Oil
level should be level with the
bottom of the oil filler neck i got that from the manual
Aug 15, 2009 | Garden
Pressure washer that leaks oil through the air breather
Most likely your air filter is plugged or dirty, or the crank case vent valve needs to be cleaned.if it still does it check that the oil level is at the full mark, if overfilled it would cause the same problem.
Jun 22, 2009 | Karcher 2500 PSI Pressure Washer
Honda 5hp engine wont run
check oil level. it has a low level shut off switch ?? May be it
May 04, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
61 people viewed this question
Top Karcher Garden Experts
Martin Grech
John Trevino
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
