Question about Magix Movie Edit Pro 15 Plus for PC
Trying to move a short film i made on to another
Trying to move a short film i made on one computer (that isnt hooked to web to another computer so i can burn a dvd copy of it or  but it says it can not find the files associated with the film....did i save the short film wrong? (not very computer savvy so go easy on me)
Posted by jollykyle on
  • jollykyle Aug 06, 2009
    Thanks mission man....is there an easier way to put all those clippings together (about 100 ) with the saved movie?
Francis Mark Arango
    President:
  • 828 Answers
DVD copy methods are importing or add only a *.VOB files. Render it again by saving a mpeg4 file or VOB file.
Now if your short film record on mpg or avi, it's not really accept by your Burner. Or maybe you using a NERO application so it's not gonna work. Try to use a program Ashampoo Burning Studio. AVI format is acceptable to record into DVD.
Posted on Aug 06, 2009
  • Francis Mark Arango
    Francis Mark Arango Aug 06, 2009
    Use Windows Movie Maker. You have it on your system. The very easiest movie maker program to add clips, pictures, and movie too.
Anonymous
  • 93 Answers
It loos like you might have to coppy all the clippings that you have made the film with on to the disk too.
(Also make sure that you are not burning shortcuts onto ur disk)
Hello, When I tried to reinstall windows on a formated drive, after I changed the boot sequence , before starting bios it requires a password. Plese help
Easiest way is to reset the BIOS. If you remove the battery, and leave it unplugged and without it's main battery and BIOS battery, it should clear it.
This is another reply posted by another tech:
Toshiba A215 Password Removal By purpledog1 on Aug 18, 2008
Follow these steps to remove / disable the BIOS (CMOS) Password on the Satellite A210 / A215 (PSAFGx ) models:
1. Turn the computer OFF, if it's on.
2. Remove the memory module cover, on the bottom of the computer.
3. Check the configuration of memory modules in the two sockets. It's necessary to have a memory module present in the outermost socket only.
  • If there is a memory module in only the outermost socket (the one farthest from the system board), then continue to step 4.
  • If there is a memory module in only the innermost socket, move it to the outermost socket.
  • If there are memory modules in both sockets, remove them both, then re-insert one of them into the outermost socket.
4. With the computer oriented as in the photo above, carefully peel back the black Mylar film. Pull this film to the side enough to expose the B500 solder pads (see photo below). Tape the film to the computer's case, as shown. Do not remove the film completely, because it may be difficult to re-attach it correctly.
5. Short the B500 solder pads on the system board. Needle-nose pliers or a flat-blade screwdriver works well to short them.
6. While continuing to short-circuit the solder pads, turn the computer on, and continue shorting the pads until the Toshiba Logo Screen disappears.
7. Re-position the Mylar film over the system board.
8. If you removed a memory module, turn the computer OFF, then re-insert it.
9. Re-attach the memory slot cover.
10. Restart the computer to verify that the password prompt no longer appears. If it does still appear, then repeat this procedure, starting with step 1.
Jul 26, 2011 | Toshiba Satellite A215-S4747 Notebook
Cant wind up film!?
You haven't stated whether you activated the rewind knob before trying to rewind the film. Unless you do so, the rewind crank will not work.
The rewind knob is to the left of the lens mount (as viewed from the front of the camera), above the self timer lever and is marked with a letter "R". Turn it until the bar is horizontal and you should then be able to rewind.
if this has fixed your problem then please take a moment to rate my answer. If it has not done so, then please add a comment instead and I'll come back with additional options for you when I'm next online.
Jul 20, 2010 | Olympus Om1 Om1 Service Parts User Manuals...
Cam isnt hooked up to monitor
You will need to install the cam software - open that and choose to film a video.
Jun 13, 2010 | Microsoft LifeCam VX-3000 Web Camera
I forgot my combination for my samsonite briefcase
Hello my name is Troy Ruff, I run a small production company called, Ruff Productions. The issue is when I move the head slowly it makes a popping sound and it ruins the shot every time. This has to be a defect. I bought this about a year and a half ago and it started doing this about 6 months in, I keep really good care of my stuff and have used it maybe fifty times. I spent around $1800.00 and I really need this fixed, I do a lot of short films and some feature films. Please let me know what I can do to get this fixed as soon as possible. Thank you for your time. Troy Ruff Ruff Productions 559-907-0000 web: www.ruffproductions.net
Apr 10, 2010 | Samsonite Tripod
Cant watch the movie
ok if you are watching a normal dvd in it then it should work if not try cleaning the disk if you are some of the people that stand there xbox 360 upstraight try laying it flat this could be the problem but if your trying to watch something from the video feature on the xbox 360 dashboard then you must have you xbox hooked up to the computer and download them its really only there for watching game previews ,short films ,and events ... i hope this helps
May 07, 2009 | Microsoft Xbox 360 Arcade
Vaccuum hose coming from transmission isnt connected to anything
I think you are talking about a vent hose. The new vehicles haven't used vacuum controls on trannys for a long time. Yours would be computer controlled. In short, the hose probably hooks to nothing....
Apr 19, 2009 | 1999 Nissan Maxima
Bios Password
Hi there.
4. Carefully peel back the black Mylar film. Pull this film to the side enough to expose the B500 solder pads. Do not remove the film completely, because it may be difficult to re-attach it correctly.
6. While continuing to short-circuit the solder pads, turn the computer on, and continue shorting the pads until the Toshiba Logo Screen appears. then remove the short.
10. turn on computer, if it boot password has been removed.
Good luck and thanks for using Fixya!!
Feb 19, 2009 | HP Computers & Internet
Keeps re-focusing in video mode
Hi Graham,
this is quite normal, I have just tried that with my camera. Unless I do not move my camera at all, it is quite okay ( I was filming my parrots in a cage ) but if you move it, it needs to focus. It just is not made for serious filming, just occasional short movies. IF you think yours is too bad, make a short movie load it into youtobe and let me know. I will then try to see wether it is not ok.
Vladimir
Oct 10, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
How Do I Edit the Film?
Look for the output jacks on your camera, hook them to your computer's audio/video input. Try accessing the recording utility on the computer then upload footage through NTSC format. You can then edit the footage. If your camera and computer utilize S-video, use them for best resolution
Mar 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
Magix Movie Edit Pro 15 Plus for PC  Logo
269 people viewed this question
Top Magix Computers & Internet Experts
Marvin
Marvin
 Grubhead
Grubhead
Are you a Magix Computer and Internet Expert? Answer questions, earn points and help others
