SanDisk 1GB microSD Memory Card Logo
Posted on Aug 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vista recognizes the disk but wont open anything
Removable disk show up on my computer but when i go to open it it says " please insert disk into removable disk" its from a verizon phone im putting it in with the larger blue adapter.
Anonymous
Level 2:
  • Expert 93 Answers
  • Posted on Aug 06, 2009
Anonymous
Expert
Level 2:
Answers
93
Questions
0
Helped
22554
Points
288
Try keying in the address of ur removable disk directly onto ur address bar. if not change ur usb port and try again.
2answers
HPv165w recognized in Device manager...But cant open it in My computer..
Try inserting the pen drive into another computer to see if you can open the data on this pen drive.
If not you may need to format the pen drive.
My dell computer wont boot up and my CD drive wont open
first remove the power and inspect the power to the hard disk remove the power connector and insert any other power connector and power on the system and see the cd led is blinking and still you are not able to open the CD cover use a needle and insert the needle in the hole just below the CD tray and push it lightly the CD cover will open now also check the power and id cable of the hard disk now restart the computer and see whether both device are recognized by the system in the post bios
Using Windows Vista on Dell Dimension Desktop: Windows Explorer does not show a DVD drive. The eject-close button does not extend or retract the disk tray. I have opened the tray manually with a...
try method 5 listed on this site:
https://support.microsoft.com/en-us/help/314060/your-cd-or-dvd-drive-is-not-recognized-by-windows-or-other-programs
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
My USB giving message of Insert a Disk into drive !
Your USB IS DAMAGED TRY TO PULL OF THE COVER OF THE USB DAN CLEAN IT WITH A TOOTH BRUSH OR ANY SOFT BRUSH DAN PUT IT BACK TO YOUR COMPUTER AND GO STRAIGHT TO MY COMPUTER AND FORMAT IT USING QUICK FORMAT SYSTEM. :)
1helpful
Computer will no longer recognize microSD
Go to Device manager and totally remove/un-install ALL/ anything USB...
Then reboot the PC, DO NOT plug anything USB in yet.
PC will start then install usb structure.. then reboot.
NOW try ya USB things ... ya prob good to go.
Disk drive wont open , problem started when it became unreliabl opening then computer would not recognize an inserted disk, the the tray does not open at all.
You will have to open up the computer and physically remove the drive. Either the cable is the problem or the drive is u/s. They are pretty easy to remove and replace, also they are not expensive to buy...try ebay for some good cheap drives!
My driver doesn't recognize the disk of Age Of Mythology
Does it recognize any other disks? It could be a problem with the disk drive itself.. maybe try getting an external USB-disk drive for testing. It may show issue's with the disk drive itself and you may need to replace it.
I need help opening a file saved on my memory stick with my pc
IF the win98 box wont recognize the usb stick you will need to install the drivers in order for the OS to recognize the device, after this you should be able to see the device and files on it
The computer read the driver but it doesnt open
It sounds like Vista has recognized the device as a CD-ROM drive, but NOT as a DVD-ROM drive, and the disk you have inserted is a DVD.
Try getting an updated driver and possibly a new firmware from http://www.lge.com/support/software.jsp
If my advice was helpful please vote for me!
Top SanDisk Electronics - Others Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
