Question about Pramac Electrical Supplies
Pramac Diesel generatorGSW 65 &GSW 80,in both generator we are facing problem that make them shutdown automatically and message displayed is SD AMP unbalanced? what should i do to solve the problem?
Posted by Hasan on
Bart Walker
    Novelist:
  • 206 Answers
I don't know your equipment, but the unbalanced term may refer to too large a load connected to one leg of your split phase service. Go to your load panels and try to get the amps drawn by your loads to be more equal. You may be over taxing one leg and have available capacity on the other, assuming you are running a 110/220 V split phase output.
Posted on Mar 15, 2019
4 Related Answers
Anonymous
  • 474 Answers
SOURCE: need to change oil on my generator Pramac 16 hp
brigsandstratton.com
Posted on Oct 31, 2009
Anonymous
SOURCE: portable generator head stopped making power
portable generator head stoped making power engine runs fine sircut brakers are fine
Posted on Mar 16, 2010
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: perkins 3 cylinder powered pramac generator
Start looking at your safety circuits.
1. High water temp
2. Low Oil
3. Low water etc...
From the manual these are the protection circuits.
• Engine protection: low oil pressure, high engine temperature.
• Genset protection: under/over voltage, overload, battery charger failure, battery voltage out of limits,
under/over frequency, start failure.
• Circuit breaker protection: IV poles.
• Differential protection.
Any one of them will trip the fuel relay closed. What you may be able to do is disconnect one at a time each protection circuit and see when the fuel relay opens. (Make sure to reconnect each one if it had no effect on the fuel solenoid)
Once you isolate which circuit it is in then you can chase wires or change the bad switch.
Thanks for choosing FixYa.
Kelly
Posted on Jun 26, 2010
emissionwiz
Marvin
  • 85239 Answers
SOURCE: pramac diesel generator p4500 was running then stop how can i tell if any diesel in the pump
Crack open an injector line.
Posted on Jun 29, 2017
Can I parallel 2 hyundia hy2000si generators together
No. You would have to synchronize them, and that's a difficult task.
May 05, 2015 | Car Audio & Video
My diesel pramac P9000 generator engine is not starting even cranked for long time what is the problem
Check and replace the spark plug, clean filters and try again. If this doesn't fix it, it is probably the carb. Clean it and try a SMALL squirt of starter fluid
May 14, 2014 | Pramac Electrical Supplies
Pramac 25 kva perkins encl diesel genset will not start red light on triangle on check list
Hello. Maybe you have solved your problems. But I still want to share the helpful article to you. https://www.dieselgeneratortech.com/diesel-generators/why-diesel-generator-fail-to-start.html
We are Perkins diesel generator OEM. Can provide 22KW to 2200KW diesel generator set with Perkins engine. https://www.dieselgeneratortech.com/perkins
Dec 09, 2013 | Pramac GBW30P Encl Diesel Genset w/Perkins...
How to change oil in pramac gsw 50kw towable generator?
If you have a Yanmar engine...
There is a hose that is connected to the oil pan in place of the drain plug directly under the oil filter that will have an end cap. This hose is used to drain the oil into a waste container.
Download the service manual located at the address below and follow the instructions in the manual.
http://www.martindiesel.com/Documents/New%20TNV%20DIRECT%20Service.pdf
Hope this helps.
Aug 21, 2013 | Pramac Electrical Supplies
Phase voltage is not same
What is your problem and what is the question?
Apr 16, 2013 | Pramac GSW120P-208 NA GSW Series 90000...
Hello i need to find a capacitor for my sumec diesel generator (ccbb61 30uf 300vac) cant find one anywhere please help
Capacitors are normally in the end of the alternator, remove the end cover. Most generators it is there
Sep 11, 2011 | Yanmar Diesel 5500 Watt Pramac Generator
Its 230kvaperkins generator it starts normally,but after thirty minutes it shuts dawn automatically indicating low frequency
Low frequency means the RPM of the motor has fallen off.
Check your fuel is NOT contaminated or fuel filters plugged.
Further tests should focus on the govenor system. Possibly it fails when engine gets hot. the frequency is directly proportional to the engine speed.
Apr 01, 2010 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Portable generator head stopped making power
Mar 16, 2010 | Pramac Electrical Supplies
Can u esplain about trouble shooting in diesel generator
my 500 kva diesel generetors dosnt work since mornning its workes after 4 houres when the weather changed
Oct 25, 2009 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Electrical Supplies Logo
137 people viewed this question
Top Pramac Electrical Supplies Experts
Marvin
Marvin
Robert Wooley
Robert Wooley
Ngoro
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
