Do you have the safety key in? Generally treadmills wont work without one plugged in.
Testimonial: "yes it is on the dash, its a magnet, and its on the yellow circle where its supposed to be"
https://www.livestrong.com/article/40689...
There is some good general tips here to review.
SOURCE: AHHHH!!!!
Just had the same thing- I blew out the plug port and re-plugged it in, charged for an hour, and now it turns on.
SOURCE: Sansa E250 Black screen lighted wheel, wont do nothing else.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
SOURCE: my asus d1500t wont startup
Most likelly your motherboard went bad, but you can try somthing else before replacing your MB.
1. Remove your battery and try to power up. Your battery might be shorted.
2. Remove your hard drive and try to power up.
3. Remove your CDROM and try to power up.
Good luck.
SOURCE: no singns of life
Sounds as though your ac adapter is bad.But it could also be the power jack where the ac adapter plugs in also.
SOURCE: tv wont turn on
reset button is usually under setup>picture>other. however your problem may be because of the lamp. If your TV is 4-5 years old you may need to change your lamp.
