5.1 Distance : Unit of Measurement This setting allows you to change your distance measurement from yards to meters. The default setting is set to yards. ? The tab next to "Distance Unit" in the tools menu, shows the current unit of measurement that your unit is set to. To change from yards to meters and vice-versa, touch the tab, and then touch "Done" on the bottom of the screen, to save the setting. https://golfbuddyglobal.com/doc/usermanual_worldplatinum.pdf
Posted on Mar 13, 2019
SOURCE: Have golfbuddy wtx how to change yards to meters.
Posted on Mar 07, 2018
SOURCE: change my golf buddy from metric to yards.
It should be noted that the GolfBuddy GPS is preset to yards. If you or someone else accidentally changed it to metrics and are wondering how to set it back to yards, here's what you need to do.
First, you need to access the Play Golf Menu by pressing and holding the OK button for 2 seconds. Scroll through the selections using the arrow buttons, until you reach the Y/M selection. Press and hold the Plus button on this menu option to change between metrics and yards. Make sure to set your units correctly before playing and test if the device is properly functioning to avoid interruptions.
Having a GPS handy whenever you play can greatly speed up and improve your game. Check out golf GPS reviews to find the most compatible device for your needs.
Posted on Apr 26, 2018
