Question about Maytag M800 Smartfill Removable Tank Iron and Steamer
Maytag M800 iron (brand new) auto shut off indicator light starts to flash within seconds of turning on
Posted by Judy K on
Can i get a manual for a rowenta effective DW1040 Auto-steam iron
you sure on the model number as it is not in
http://www.sav.rowentausa.com/Pages/instructions.aspx
suggest re checking the reference number as shown on the web page at rowenta it may be different and searching for it in the web page as I am having hard time finding anything for DW1040
Aug 13, 2016 | Rowenta Effective Iron Auto-Steam Iron...
I just need to Register this New Iron I just purchased....
fill out the card and post it off or contact the service department of the company( manufacturer)
May 20, 2015 | Black and Decker USA Black & Decker The...
When has my iron stopped steaming and heating up?
depends on how old it is, try to rinse it with a water and vinegar solution, this might help
Apr 09, 2015 | Euro Cuisine Ootoo Iron, 1500 Watt Steam...
Eurosteam iron no power
try it in another power point , otherwise have it repaired at a service center . not suitable for home repair.
Nov 13, 2014 | EuroSteam Steam Iron w/Boiler Tank & Lint...
Elna ironing press manual
I don't have a manual but these are extremely simple to use once and there is a demo on youtube for business shirts How to use Elna Press for Ironing Shirt and other videos from same member show sheets and jeans. Technique is simple, place part of garment onto the board with the rest sitting on your knees (use press sitting down in front of it) to take the weight, lower press closed with your left hand, then bring the spring loaded right handle down to apply the pressure, this has a big spring behind it and applies pressure, wait 2-3 seconds then lift right handle to release the pressure and then using your left hand grip the whole press will want to open up again. That's it! Set the temperature setting on the press and iron from your lowest temperature items first, nylons, up to cottons, linens on the hottest setting last as it will take 5 minutes or so to come up to full temperature. If you have the vapojet spray attachement, then you fill this with tap water and slide it onto the handle, give it a spray with the press open before you close to press and it turns to steam. Cleaning the top hot plate can be done with a special cleaning stick product you can buy (or any similar iron cleaning stick will work too, but you need to apply it to a hot plate so be really careful as you do this, then wipe it off with some waste fabric. Great press to own and perfect for applying interfacing if you are a sewist, (just use a piece of waste fabric so side of the interfacing doesn't attach to the top plate or your bottom cover).
Jul 12, 2014 | Garment Steamers & Presses
Heating pad is wrinkled so clothes come out wrinkled
I thought my old one was faulty so I bought a new one and still experience the same wrinkling problem!
Dec 22, 2013 | Corby Trouser Press 7700
I " inherited" this iron without a manual. How do I retract the cord on my cordless iron? It refers to a button but I can't locate it.
I never saw an iron with a retractable cord . The cover would have to be large enough to accomodate the cord and the heat from the iron could melt the cord. Are you sure it supposed to work like that?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 24, 2013 | Panasonic Appliances Steam Iron with Spray
Maytag M800 Smartfill Removable Tank Iron and Steamer Logo
238 people viewed this question
Top Maytag Garment Steamers & Presses Experts
Tom Chichester
Bill Boyd
ray gallant
Are you a Maytag Garment Steamer and Press Expert? Answer questions, earn points and help others
