SOURCE: GE JTP56 Double Oven
Hello there, This may be related to the F7 problem even if you are not getting an error message. Go to my web site at the following link: http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf Please let me know if this works for you. I have sent my fix to over 1300 folks. Good Luck, Powerman
SOURCE: jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
SOURCE: jenn aire
Maytag-Maycop-Magic Chef-Jennair-Admiral
Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
SOURCE: Jenn-Air S160
What is 15 year old Jenn air stove, model S 160 worth? It is in good shape and has just recently been checked by SEARS and operates fine. New racks, new knobs, and new broiler pan. Completely cleaned up. Looks like new!
SOURCE: oven door locked - jenn air
My Jenn-Air double oven locked after a clean cycle. My model (JJW8630) has a series of slots cut in the top of the door. Take a piece of stiff wire, coat hanger, and bend a right angle about 1/2 inch at the end, feed the wire into the 3rd or 4th slot from the center on the right hand side. Turn the wire so that the bent piece is on the top and push the wire so it engages the lever which latches the door shut, it is spring loaded and moves easily.
Once the door was opened, I removed the temperature sensor, held by 2 screws, from the top of the oven and eased the wire out to get to the connector. The faulty sensor was reading 4.2 k, at room temperature it should be just over 1k, while waiting for a new sensor to arrive I stuck in a 1k resistor, ex Radio Shack, so the fan stops running and the door latch can be retracted by closing the oven door, or press the switch on the top right of the door opening.
My replacement part was ordered on line for less than 1/2 the official quoted price.
Hope this helps.
