Question about The Kitchen Appliances - Others
The toast will not stay down - The Kitchen Appliances - Others
    Top Expert:
  • The Master
  • 5,478 Answers
Make sure that there is not any obstruction in the bottom of the toaster like old toast. If that is not the problem, get a new one.
Posted on Mar 13, 2019
2 Suggested Answers
6ya staff
SOURCE:
Ian Prins
Ian Prins
  • 11 Answers
SOURCE: toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Posted on Dec 06, 2007
Repair of model 553 krups toaster over. Lever will not stay down to toast
if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
May 05, 2018 | Krups Toaster Ovens
Control lever will not stay down
Unless you have power switch on to the toaster, the level will not stay down. Ensure you have main power available!
If the unit is powered, check that the 'toast darkeness' level is set accordingly - it is this 'thermostat' that determines when to eject the toast: if you checked that you have power and that the darkness level is not set to zero and it still does not work, then it is time to get a new toaster! If not under warranty, it is probably not worth trying to get it repaired.
Apr 08, 2014 | Bodum 10709 Toaster
My toast lever wont stay down-I've loosened the cover and cleaned as best I can. How can I take the lever off so that I can fully remove the cover? It is a Cuisinart two slice black toaster.
On most appliances the knob on the lever pulls off and the cover is then lifted off the lever. Check that the bi-metal strip that latches the toast ejector has not been bent or damaged. Once you have the cover you will be able ot see the whole mechanism.
Jan 26, 2011 | Cuisinart Kitchen Appliances - Others
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Kitchen Appliances - Others
Toaster does not stay held down to toast wct 708
there is a "contact switch" that when there is power in the system, it stays down. If hte contact switch is bad, it releases and will not stay down. COntact switch needs to be replaced, unfortuantely I have the same problem and can't seem to get the part.
Jun 12, 2009 | Waring WCT708 4-Slice Toaster
BTA320 bought today. Lever wont stay down to toast.
Since this is brand new, I would suggest return it for a new one.
May 02, 2009 | Kitchen Appliances - Others
Toaster lever wont stay down
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
Kitchen Appliances - Others Logo
48 people viewed this question
Top Kitchen Appliances - Others Experts
Carlos Alvarez
Level 1 Expert
debbie
Level 1 Expert
sureshd2008
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
