Televison & Video Logo
Hi my OVHD Decoder is not responding to the remote. And if I manually switch on I dont get sound could it be the remote or actual decoder that is faulty
Posted by Anthony Atkinson on
Lukas Alexander
  • 21 Answers
Check the filter curcit the capacitor or ic is probably bad
Posted on Mar 13, 2019
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: Harbinger Decoder
Okay, I'll try and help you out...
1. Create new folder on desktop called 'recordings' or something similar i.e. easy to remember!
2. Connect unit to PC via USB cable and turn on the unit. If you slide the HOLD switch to the on position, you should get a message saying "PC LINK" on the display.
3. Locate the recording(s) that you want to decode. I don't know what model of denpa you have, so I can't be sure, but there are normally four folders (A, B, C, and D - there may also be an MP3 folder). The recordings are accessed by double-clicking my computer, then the removable disk icon that appeared when you plugged in and turned on, and then opening the folders that are present which contain the recording(s) you wish to decode.
4. Identify the recording(s) you wish to decode and copy them to your newly created desktop folder (right click the file/copy and then go into new folder and paste there).
5. Once you have copied the file(s) you want to decode, open the Converter program (programs - harbinger converter - converter 1.4).
6. In the program window click on the magnifying glass in the top box (source file) and browse to your new folder.
7. Select the file you wish to decode (I think you have to do them one at a time - just repeat the process for each one following these steps).
8. In the lower box (output file) enter the name you wish to use to identify the file so you can find it. Then click on the magnifying glass for the output file and browse to your newly created folder (this will then be where your converted files will be sent on decoding).
9. Click the 'decode' button in the lower left corner of the program window (I think it shows a picture of two different sized cogs side by side).
10. The file should then be decoded from its .hgl format to a (new) .wav format with whatever name you gave it. From here, you should be able to listen to the file on your PC using any common media player (i.e. Winamp/Media Player etc.) or recode it as an .mp3 if you want to save some hard disk space on your computer.
Repeat the process from step 6 for each file you want to decode.
Hope that helps and good luck.
Posted on Dec 12, 2007
Anonymous
SOURCE: dvd decoder
Download here: http://www.uberdownloads.com/11519/details-media-player-codec-pack.html
Posted on Aug 02, 2008
Anonymous
  • 80 Answers
SOURCE: i can,t able to play dvd's on window media player
well you can download the vlc program which can easily play the all format videos........this program u can download it from here
http://www.videolan.org/vlc/download-windows.html
Posted on Aug 28, 2009
Anonymous
SOURCE: proton enhanced surround decoder help
You need the remote for it only way to turn it on.
regards
Posted on Oct 18, 2009
Anonymous
SOURCE: My decoder - dsd 1131
Don't worry about it. You have mistakenly pressed Shift + exit. What you need to do is to press Shift + i. What you have done is used by the people using two decoder. They use it to switch between the two decoders.
Posted on Dec 30, 2010
My OVHD Decoder is not responding to the remote. And if I manually switch on not responding. all buttons not responding, but power is there and showing a green light but nothing on the screen
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it.
https://electronicshelponline.blogspot.com/
https://elektrotricks.blogspot.com/
https://electrohelponline.blogspot.com/
2answers
Activate my openview decoder please.STB Id is 31 9023 5609 31
Connect the cable from the dish to the LNB-IN port and switch the OVHD decoder ON. The decoder will pick up the OVHD signal automatically. The decoder must be activated using the cellphone by entering *120*6843*1# and then follow the menu.
https://www.spacetv.co.za/wp-content/uploads/2018/11/openview-brochure.pdf
1helpful
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
1helpful
2answers
Connecting pvr dstv decoder 3001
My pvr decoder model 3001 remote control doesn't work I checked battrey it works but no answer for decoder what shall I do
Top Televison & Video Experts
Marvin
Marvin
