Question about Braun Health & Beauty
Braun Thermoscan 6022 is not switching on. Used it perfecto last night, this morning it's not working. Changed batteries... still nothing
Posted by Diane Desilets on
5 Related Answers
Anonymous
  • 276 Answers
SOURCE: have a braun thermoscan and want to change it from...
From the manual of the thermometer:
This thermometer is shipped with the Fahrenheit temperature scale activated. If you wish to switch to Celsius (°C), proceed as follows:
• Turn on the thermometer. (If it is already turned on, make sure it is not in memory mode.)
• Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
• By pressing the activation button again, the Celsius scale is activated, «°C» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
If this isn't the right manual, go to: http://braun.kaz.com/kaz/service and select your country from there.
Posted on May 19, 2010
Anonymous
  • 8 Answers
SOURCE: I have a Braun Thermoscan
... call Braun ThermoScan customer service at 1-800-327-7226
Posted on Feb 19, 2011
Anonymous
SOURCE: I have a Braun thermoscan type 6022, but code po5
It's not po5, its pos... you're not positioning it properly in the ear canal.
Posted on Feb 21, 2011
Anonymous
  • 8 Answers
SOURCE: I have a braun thermoscan 6022 after it displayed
Ambient temperature is not within the allowed operating range (10 - 40 °C or 50 - 104 °F).
Allow the thermometer to remain for 30 minutes in a room where the temperature is
between 10 and 40 °C or 50 and 104 °F.
Here is a link to the manual if you should need it:
http://braun.kaz.com/files/IRT33020COGB,%20F,%20E,%20P.pdf
Posted on Mar 17, 2011
Anonymous
  • 8 Answers
SOURCE: I have a Braun ThermoScan Type6013 have changed
Problem:
Temperature taken is not within typical human temperature range (93.2 °F - 108 °F / 34 °C - 42.2 °C).
Solution:
Make sure new, clean lens filter is properly inserted. Then, take a new temperature.
6helpful
2answers
Can you change the temp reading from F to Celcius on a Braun Thermoscan 6014?
Turn off the thermometer
Press and Hold the L/O Button
Continue to hold the start button when the F or C display appears. Watch for these displays to cycle over the display window.
Release the start button when the F display appears on the screen.
5
Listen for a beep and watch for the Braun ThermoScan ear thermometer to shut itself off, indicating that you changed the temperature scale to Fahrenheit successfully.
6
Follow the same procedure but release the start button when C shows on the display to switch from Fahrenheit to Celsius.
19helpful
2answers
I have a Braun thermoscan type 6022, but code po5 always comes up. What does that mean?
Health & Beauty Logo
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
reference30
Michael Thomas
Michael Thomas
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
