Question about Fisher and Paykel E522B Stainless Steel Bottom Freezer Refrigerator
My Fisher and Paykel frig E522B the display options are only half working there is no error nombers and it isn't in the sabbath mode
Posted by Marie Irwin on
5 Related Answers
Anonymous
SOURCE: THE TOP PART (FRIDGE) IS NOT COOLING
We had the same problem. The duct between the freezer unit and fridge is probably iced over - a design problem apparently. Allowing to completely defrost will solve.
Posted on Aug 14, 2009
reddyanantha
anantha reddy
  • 205 Answers
SOURCE: I have a Fisher and Paykel E522B Fridge and the
hello sir/mam
after replacing the tempreture probe have u checked the compressor so that it should get the signals for cutt in and cutt off if not please check it.if this is not happening please change the temperature sensor.
Posted on Sep 14, 2009
Testimonial: "which temerature censor ( there are three )"
Anonymous
  • 1430 Answers
SOURCE: Our E522B Fisher & Paykel fridge no longer making ice?
Try the video on checking the F&P icemaker.
www.appliancehelponline.com/servicemanual.html
Posted on Feb 27, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Fridge compartment not cooling. Freezer
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 07, 2011
sonicboomele
sonic boom electronics
  • 1557 Answers
SOURCE: What is fault code 2
The resistance of the Evaporator Sensor is outside of the normal range (> 45k ohms).
Primary Action
- Check sensor connection at controller.
Secondary Action
- Replace sensor.
Posted on Jul 11, 2011
If I go into sabbath mode for my Fisher Paykel fridge is it still running
A set of standards have been arrived at which address all the concerns of observant Jews in relation to appliances during the Sabbath.
This article explains -
What is Sabbath Mode Choosing Star Certified Appliances
Oct 11, 2017 | Fisher Refrigerators
If you go on the Sabbath mode with your fisher ankle fridge will the fridge motor keep the fridge cold Paula
Yes... Paula,
Hello Paula,
Let's say... (for example)
Your FISHER & Paykel model number is E522BLXU...
on that model... (read about Sabbath mode)
Page 10 of those
instructions
says of manualslib.com (URL link below)
"When in this mode, the alarms are deactivated and the interior
light and back light on the display will not come on. The interior
fan will not turn off when the door is opened.
To activate press and hold MENU + DOWN + LOCK for 4
seconds"
Of course the precise buttons could vary... WHICH is why
putting in TOUR MODEL NUMBER is important for
such questions ...
Reference
Fisher Paykel E522BLXU Service Manual Dispenser Lock Key Presses measured...
Hope this helps
Carnac the Magnificent
Is it possible to reset display on F/P frig display panel E522b powr outage yesterday cooler----- warmer display blank
Your refrigerator could have been a victim of a power surge or spike.
Modern appliances have circuit boards which are highly susceptible to surges & spikes and you really should have these type appliances plugged into a surge/spike protector.
If all else fails, have a qualified repairman come take a look at it, or contact the manufacturer.
Dec 13, 2017 | Refrigerators
Fisher snd paykel e522b ice snd water frudge not dispensing chilled water. Also only half display is working.
U may need to get it re-gassed? or it may be a wire running to the water chiller
Oct 31, 2013 | Refrigerators
Led display is failing on my fisher and paykel fridge model number E522b .
I'm not sure that I can help with the problem, however, I did find a replacement parts website here:
http://www.searspartsdirect.com/partsdirect/part-model/E522b
You'll have to find your exact model since there are several Fisher and Paykel models listed that start with E522B. Additionally, they have the user manuals online to look at so it's possible you can find the troubleshooting section in the manual and solve your problem.
Feb 26, 2013 | Refrigerators
I have a fisher and paykel E522B refridgerator and the door handle is coming off. I need to know how the door handle is attached so I can retighten it
In most case the screws are hidden, some of the handles have a cover that slides up or down, and the others have a little hole cover that have to be popped out and then you can access the screw
Dec 13, 2009 | Fisher and Paykel E522B Stainless Steel...
hello sir/mam
Sep 14, 2009 | Fisher and Paykel Active Smart E522B...
Fisher and Paykel E522B Stainless Steel Bottom Freezer Refrigerator Logo
159 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Muntejaya Ginting
Muntejaya Ginting
NOEL
NOEL
john h
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
