Question about LG Televison & Video
LG TV. Why did it go blue? - LG Televison & Video
Posted by Chuck-Carol Fahey on
42inch LG plasma TV
well if you could please give out the model nuumber thank you
Why can't I record on my DVR?
Check all your connections and configuration between decoder to DVR and TV. I find it is more practical to use the DMI connectors for this purpose. Between my LG TV, LG DVR, LG Blue Ray Player and Decoder I use 3 DMI connector cables. Ideal for me because my TV has 3 DMI points, I just connect each of 3 items to TV via a DMI cable. Now connect decoder to DVR via video-audio cable (red-white-blue). This setup allows each unit to be used individually (i.e. tv viewing, recording, blue ray playing and when recording live TV the TV can be switched off while recording. Just remember to select the appropriate DMI connected unit on your TV remote (on "input" button).
Silicon power a80 has all my movies on it from my mac book but now i try plugging into my tv or blue ray player and router and nothing will recognize it
A: Does your tv have a usb port and drivers to recognize a hard drive? WE don't know you did not provide that information.
B: Same for your Blue ray player
C: Same for you router
D: Mac file system is not the same as Windows file system
LG CRT TV Problem
It sounds like your picture tube is either shorted at the blue gun or there is a blue drive problem. The blue driver transistor can short and cause the same problem. If it has little fine white lines as well, most likely it is the tube. Thanks for using fixya.
2helpful
LCD LG TV 37LG50 / Samsung bd-p1500 blue ray player
644 works with the Samsung BD-P1590/BD-P1590C/BD-P1600 om my Blue Button Dish Remote for the 722k.
1helpful
2answers
Blue dots and blue screen on Hitatchi 50"
Bad Light Engine Call UED for rebulit one 1-800-648-6657 They are not cheap.
Screen color is blue
A blue screen normally comes on in AV or EXT mode, try changing the tv settings back on the controls in TV mode
I hopethis helps
Lg 150 cm rear projection
this is the engine problem cause by the blue lcd inside the engine if you can find the blue lcd you still have to do the converion. by lg technician
Televison & Video Logo
Ekse
