Question about Crosley Audio Players & Recorders
Cd player in crosley cr837 will not play - Crosley Audio Players & Recorders
Posted by dyager5114 on
5 Related Answers
Anonymous
  • 1067 Answers
SOURCE: crosley songwriter cd recording problem
maby the formatt its wrinting on is ther any options in menu of it to set the output formatt to mp3
Posted on Jan 22, 2008
mydogisk
Kenneth
  • 50 Answers
SOURCE: crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
Posted on Apr 10, 2009
Anonymous
  • 17 Answers
SOURCE: I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Posted on Jul 24, 2010
SOURCE: Why does my crosley turntable/cassette player/cd
I would suspect that you have a bad record laser in the CD recorder assembly, this is common, and this is usually what it is. To this end you would need to replace this unit's laser assembly, it will/may still play a CD OK, but will not write to the CD, as they are two separate lasers. So if you wish to try to repair you will need to contact Crosley and ask them what to do, ask for a referral to an authorised service center or perhaps even return it to them? In any event ONLY ask for a "Quote" first and see how much it may cost before proceeding.
Posted on Oct 17, 2011
Mike
  • 884 Answers
SOURCE: i just purchaseday crosley model #2405c and when you put a cd in and push play button it does not work
Hi
You can find a manual here
http://imgserve.crosleyradio.com/manuals/CR2405C%20manual%20%20%20English_French_Spanish%202011.12.19.pdf
which may or may not help with your problem.
However you state that you have "just purchased" the machine. If this is so and particularly if the machine is new then you should take it back to the vendor for him to replace with a working unit, because clearly the one you have is "not of Merchantable Quality".
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Dec 26, 2014
I just purchaseday crosley model #2405c and when you put a cd in and push play button it does not work
Hi
Cheers
Dec 26, 2014 | Crosley Audio Players & Recorders
I have a Crosley combination turntable, CD and tape player. the Cd player will not open. There is a CD on theturntable and it will play.
Chances are that a small belt that drives the CD draw up and down has fallen off or broken. Going inside will reveal all.
Sep 28, 2014 | Audio Players & Recorders
CD player makes crazy, loud sound while playing. Is this fixable?
Yes, it is probably fixable but not within the cost structure of the Crosley product. On the unit I worked on, the item looks pretty much throw away by it's construction. I just worked on one recently for my aunt. I am sure the cost to repait one of these would exceed it's value.
If you are in Chicago and want me to look at it- [email protected]
Dec 05, 2012 | Crosley Audio Players & Recorders
Why does my crosley turntable/cassette player/cd recorder cuts off when I play it?Whenever I try to record from a cassette to a cd it cuts off.
Oct 15, 2011 | Crosley CR248 Turntable
Own a crosley jukebox, cr-12-3. unit is not reading the cd's. any suggestions? i tried a cd cleaning disc. still nothing
Hi
if you can open the jukebox and look for the cd unit. under the place of the disc you should see the laser head its a small lense
try to clean with a qtips could be dust on the eye
it helped me when my cd player did not play
Hope it will help
Oct 21, 2010 | Crosley Jukebox CD Player with AM/FM Tuner
Crosley CR704 record player wont work, HELP!!!
Make sure the switch on the back for line in, is off! I had mine on and it would not play. Switched it off and all works fine!
Aug 01, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
Crosley songwriter cd recording problem
Jan 22, 2008 | Crosley Songwriter (CR248) Shelf System
57 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
efs_perpends
efs_perpends
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
