Question about Kenmore Coffee Makers & Espresso Machines
Where can i get the user manual for Kenmore 12930 Elite Stainless Steel Espresso Machine
Posted by RAFAEL MENDEZ on
Kardoc
    Top Expert:
  • Kenmore Master
  • 5,995 Answers
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Stainless Steel Kenmore Elite 36 in. 2.0 cu. ft. Microhood Combination Model 63763
Generally the F9 code indicates a problem with the door latch (usually upper) or with the control board. You can do a Google search for my text file "doorsw.txt" to help you diagnose and repair door switch trouble. BUT - since it always stops at 53 seconds, that leads me to think you have trouble with the control unit (circuit board / controller assembly). Once you read and digest the info on door switches, please feel free to do an updated post and I'll be happy to help you further. It may be corrupted ROM in the control unit. But let us know what you find out. - online they call me "William E. Miller, AS-EET"
Posted on Oct 15, 2006
Anonymous
  • 3 Answers
SOURCE: Users Manual
http://www.hillbillyhousewife.com/breadmachinemanual.htm
This was helpful to me when I didn't have a user manual.
Posted on Mar 17, 2008
Anonymous
SOURCE: User Manual
Please email me tomorrow at [email protected]. I can scan my manual and send you the pdf from my office. I just need you to remind me. Thanks
dgsrgr8
Posted on Jun 01, 2008
Lee2fixit
  • 218 Answers
SOURCE: error message on fridge "er ff"
Error code Er FF indicates that the evaporator fan has failed, or at least is not sending a signal to the electronic controls. Open the door and see if the evaporator fan is running inside the freezer compartment. If that fan stops, then no cold air will be sent to the refrigerator compartment and it will warm up. Possible causes include bad motor, bad connection, bad electronics.
Posted on Jul 25, 2008
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Kenmore Elite ET3
The plastic casing (tub shell) around the stainless spin basket should not become worn unless the spin basket is hitting the outer shell. From my past experience, this is usually caused by a cracked or broken spin basket support (spider) arm on the back of the spin basket, or a shot tub bearing (which is also behind the spin basket). The bearing is actually part of the rear tub shell and is molded into the plastic. It cannot be replaced separately and requires the replacmeent of the shell.
If the spin basket supports become broken, the basket becomes off balance and rubs against the outer shell. This results in excessive vibration, which may be the reason why the support shocks were broken. No...this is not normally expected. Unfortnately, this is not a simple or inexpensive repair, either. If you have a service plan, or warranty coverage, I would recommend pursuing that as a repair option. If you wish to repair this yourself, I can post a link for you to follow, but it is expensive. This will usually require the replacement of the following parts:
Spin Basket
Rear Tub Shell (if bearing is bad)
Front Tub Shell (if spin basket caused significant damage)
Support Shocks (I would recommend replacing all 4)
Optional:
Drive Belt Pulley (can become warped or bent)
Drive Belt (if showing signs of wear)
Rubber Door Bellow (if vibration as caused damage to the rubber)
You can go to searspartsdirect.com and type in your model number to get prices for everything if you like. Everything can be found under the "Tub and Basket Parts" heading, with the exception of the rubber door bellow. It can be located under the "Door and Latch Parts" heading.
I know none of this sounds like positive news, but I do hope you find some of this information helpful. Let me know if you need further assistance.
Posted on Aug 20, 2008
Kenmore elite 5 burner grill manual
Kenmore Gas Grills Manual - Sears
https://www.sears.com/search=kenmore%20gas%20grills%20manual Items 1 - 37 of 37 - Kenmore Elite 5-Burner Dual Fuel Gas Grill with Motorized ... Star Manufacturing Star - 848MA - Ultra-Max® 48 in Manual Gas Griddle.
Kenmore Elite 5-Burner Dual Fuel Gas Grill with Motorized Rotisserie Kit
https://www.kenmore.com/.../kenmore-elite-kenmore-elite-5-burner-stainless-steel-gas... The Kenmore Elite 5-Burner with Rotisserie Kit: A Reliable Cookout Staple Play host to the perfect outdoors party with ... Play host to the perfect outdoors party with your Kenmore dual fuel gas grill. ... Assembly, Minimal Assembly Required ...
[PDF]Owner's Manual - The Grill Services Corporation
www.grillservices.com/manual-downloads/720-0286.pdf Kenmore Elite Warranty ... Burners: 5 Years. Flame Tamers: 3 Years. Cast Iron Cooking Grids: 3 Years ... grill. The gas regulator assembly supplied with your gas.
Kenmore elite 5 burner grill manual Google Search
Jul 28, 2018 | Kenmore Grilling
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
Necesito por favor ver el manual de una estufa Kenmore Elite model # 79077513800
www.managemylife.com/mmh/owner_manuals/1498/KENMORE-ELITE-Free-Standing-Gas-L0810551
May 19, 2011 | Kenmore 46123 Stainless Steel Electric...
Oasis HE 27082 Stainless Steel Top Load Washer: how do i soak whites in a kenmore elite oasis?...
There is not a program - you have to do it manually on this machine.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I am looking for user guide / user manual of the Francis Francis X1. Thanks
Go to this site www.redmonkeycoffee.co.uk select expresso machines then FF X1 you will see a link to download manual
Dec 29, 2008 | FrancisFrancis! X1 - Stainless Steel...
Kenmore two way tumble action washing machine - shakes, vibrates very loud
sounds like you have a broken stantion on the back of the basket.you can confirm this by opening the door and trying to pull up on the stainless steel basket.if it pushes up and flops back down,that is what you have.if the mach is over 2yrs old,look in your manual under warranty.if it has a 10yr on stainless steel basket and lifetime on tub,you will only have to pay for labor on repair.if it only has 1yr on entire mach,est would be higher than the price of a new one.
Sep 23, 2008 | Kenmore Elite 45986 Front Load Washer
Coffee Makers & Espresso Machines Logo
Top Kenmore Coffee Makers & Espresso Machines Experts
gbob59
Jude24
ray gallant
Are you a Kenmore Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
