Saws Logo
D
David Slavin Posted on Mar 11, 2019
Table does not activate when I hit the start button
Vincent Migliore
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 36 Answers
  • Posted on Mar 16, 2019
Vincent Migliore
Contributor
Level 1:
New Friend:
Night Owl:
Answers
36
Questions
Helped
9487
Points
79
HIt the reset button. If that doesn't work, take the motor off and vaccuum the hell out of the brushes and just clean it of sawdust. Then try it again.
Hitachi table saw motor just Hums.
Question edited for clarity.
Question moved from Laundry Dryer.
Replace the start capacitor on the motor. The classis reason for humming and not spinning. The start capacitor gives the motor a jolt to get it running.
https://www.google.com/search?q=Hitachi+table+saw+start+capacitor
Are sand and water tables considered activity tables?
An activity table is a table that have activities incorporated into them, so a table that kids would play at with water or sand would be considered an activity table.
Oct 07, 2013 • Toys
3helpful
Under the Table, I only have an X axis and no Y, but I need both. How do I create a table for the Y axis as well?
ok,
I assume that you are attempting to make a scatter plot of some sort. Here's how:
Instead of hitting the [table] button. You should hit the [stat] or [stats] button as I forget which it is. Then hit [enter] which will bring you to a stats list editor of some kind. You will want to enter the data for your x-axis in L1 and the data for your y-axis in L2. Once you have completed your lists, hit the [stat] button again and then click [right] or the right arrow in order to move to the section of calc. from number 4 down it will help create a graph of that type of function. lets say you think it is linear, so you hit [enter] on number 4 and then you will be at the home screen with LinReg already written. You just have to complete the statement and it will do it for you. hit the [2nd] [1] and then the comma button, then [2nd] [2] and [enter]. that will do it for you.
If I am mistaken in my thoughts and you have a graph that you need the points of, type the function into the y= menu or solve a few points and do the above suggestion.
The calculator will not allow you to plug-in values for the y within the table menu.
I hope this helps.
How do you get the table ([2ND GRAPH]) from the [STAT] [EDIT] [L1] [L2] list to appear with [Y1] in the second the column? The information appears in the scatter plot, but the information in the table does...
1helpful
Motor will not start on my Ridgid table saw
Check the brushes and the commutator for wear and buildup between the insulated areas of the commutator..It should be clean and not full ofcopper residue.That will make the motor click only upon triggering the starter switch
3answers
Can't log into Win Vista Home Premium
Call Microsoft.
Microsoft Windows Vista Consumer Product Activation Phone Number:
1-866-740-1256
Good luck with this.
The power button keeps blinking and I can't shut the printer off . I was printing directions from mapquestand only one page and part of another page printed. I tried several times to print again but...
I fixed the problem. I guess I hit the hold button on my printer without realizing what I had done. That's why the printer would not shut off and it was kept in the active state. I just started hitting buttons and once I hit the resume button the printer started working again.
Thanks anyway.
HELP... unlock my router
1. From the "Setup" page, click Advanced
2. When the "Filters" page opens, click on the Wireless tab
3. Make sure all wireless computers are setup to the router, and are currently able to access the internet. Once this is done, click on the Active MAC Table button.
4. Move the "Wireless Active MAC Table" window and click on Edit MAC Filter Settings on the main window.
5. When the "Wireless Group MAC Table" opens, go to the task bar and click on the Wireless Active MAC Table so that window appears.
6. With the two windows side by side enter the MAC Addresses from the "Wireless Active MAC Table" window into the Wireless Group MAC Table.
Note: When you enter the MAC Addresses do not include the dashes/semi-colon, and do not click "Filter"
7. Click Apply then Continue in the "Wireless Group MAC Table" window.
8. Close the "Wireless Group MAC Table" window and the "Wireless Active MAC Table" window
9. On the Main window Enable the Station MAC Filter setting.
Top Saws Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Saw Expert? Answer questions, earn points and help others
