Question about Nakamichi Televison & Video
My Nakamichi TV 42" not opening, remote control not working for ON/OFF, in screen showing Unfortunately, TV applications provider has stopped what can I do? some time showing Laucher isn't responding
MY TV MODEL NS4200LE 3D Smart TV is working, remote also not functioning, while switch on showing launcher isn't responding like that
5 Related Answers
Simpson Neal
  • 236 Answers
SOURCE: TV won't respond to remote(s)
I don't know of any adjustments for the IR receiver but the receiver itself could have gone bad or something may be blocking the IR lens not letting the IR signal get through. Maybe (but unusual) there may be a cold solder joint in the IR circuit. Sometimes dust will collect on the inside of the IR lens causing this problem. You can verify the operation of your remotes by holding them close to an AM radio receiver and pushing the buttons. You'll hear a popping sound through the radio speaker whenever a button is pushed. You may have to tune the radio up or down the band to pick up the remote's signal. Stargazer
Posted on Mar 03, 2007
Anonymous
SOURCE: Controls not working on Philips 28" TV
We had this problem with a 28PW6515. The control would work for 30 seconds after switching on, then nothing. It was diagnosed as the "glue chip" which handles all the control functions. About £200 to fix it as it's a surface mount chip.
Posted on Jun 22, 2007
Anonymous
SOURCE: My TV has stopped responding to the remote control (and the universal remote) and the front panel buttons don't work
waynejman, I have the same exact problem, can you tell me what your outcome was?
Posted on Nov 16, 2008
Anonymous
SOURCE: My Sony Trinitron TV does not respond to remote control commands
the tv wont come on the standy timer light is on
Posted on Jan 02, 2009
andy4254
andy williard
  • 226 Answers
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
Posted on Apr 28, 2009
Nakamichi delta 50B remote not working have put new batteries in no light showing where do I get a new remote please
I found a site that sells genuine Nakamichi remotes but please check that this listing will be suitable for you before placing an order (says suitable for 100R and 50) -
NAKAMICHI DELTA 100R replacement remote control
Ustvnow dvr tv shows unable to watch recorded shows when press play without causing tv screen to flicker twice and not able to watch tv program
It appears it is not your fault. I contacted ustvnow and they said they are "working on it" but currently the DVR service is not available on roku. If you find an answer elsewhere, I'd love to hear it
Nakamichi tv
My smart tv nakamichi, while swith on only shows android and busy, even remote not functioning. . Pls advice
I have a sanyo flat screen 42" and a remote from
Hello
Send me the exact model number of your Sanyo TV and the sony remote control which you try to synchromize with it. Without it how can I post a solution to you. Send these by Fixya please. OK.
1helpful
Remote controller for Nakamichi AV 10 amp. stopped working last night despite replacing new batteries. Red LED not illuminating when 'power' button depressed. Any suggestions for repair/replacent of...
I got the Nakamichi Av-10 i too face the same problem i just tap the remote with my palm and it starts working...:) just try this am sure it should work
2answers
Code for sansui tv with a RCA 704 remote control
Sansui has connections with the Orion, Akai and Nakamichi brand names.
However according to my information the code you should use for this TV with this particular remote control is 191.
Hope this helps. Please do rate this answer. Thanks.
6helpful
2answers
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Televison & Video Logo
Top Nakamichi Televison & Video Experts
ray gallant
Tom Chichester
Are you a Nakamichi Televison and Video Expert? Answer questions, earn points and help others
