What are the error codes on an optoma tw865 projector
SOURCE: optoma dv10 projector has a
contact optima in california. i had to after circuitcity failed to honor my extended warranty... surprise huh ??? anyway i talked to a factory rep. about the white vertical bar and he stated the unit has to come in..period. i said , so you know about this problem, he said yep, and the unit has to come in.. if your unit is under 2 years old they will warranty the repair, you have to pay the shipping to them, but they sent me a replacement unit next day air.. absolutely awesome customer service.. just google " optima projectors factory support" you will get an e-mail address. they e-mailed back immediately with a 800 number and we went from their..they were great and totally stood behind their product..
SOURCE: optoma projector
i'd say power supply issue, but the led is blinking green. this means that it thinks it's in warmup/standby mode. but if nothing's running, the main board might be bad and needs to be replaced.
SOURCE: optoma dv 10 projector, both
The flashing temp light indicates a cooling fan failure. The lamp light indicates a bulb failure.
Here's the manual: CHECK OUT PGS 19 AND 49...
http://marketing.optomausa.com/PDFs/usermanuals/Optoma_DV10_Manual.pdf
SOURCE: I installed a new optoma
Sounds like its overheating and shutting down. Disassemble the projector components as many as you can, get a can of compressed air and empty it on the projector. That should get rid of any dust that may be causing the overheating problem and resolve it. Give it a shot and let me know
