Question about Watches
How do you set the date on a charles hubert wristwarch?
I know the hands need to be in a certain position as to not strip the gears.
1 Related Answer
martin sanders
  • 12 Answers
SOURCE: user manual
Have you tried googling it either that or email manfacturer direct for one.
Posted on Sep 02, 2012
How do I set the time?
Hi Charles,
I presume you're referring to a chronometer watch?
You need to twist the crown (little screw on the right side of the piece) counter clockwise until it slightly pops out. This is position 1. You need to pull the crown outward gently until you feel a lug sensation. This is position 2. Turn the crown to adjust the 'date' until you reach yesterday's date (one date before what you actually want). Then pull the crown outward again feeling that lug sensation. This is position 3. Turn the crown so the minute-hand swings in the normal movement of time (don't swing it backwards). Keep doing this until the 'date' turns to the current date. Now your piece is set on the correct date and the minute-hand is in the "a.m." Now keep turning the crown until you've reach the current time (noting the am/pm period you want). Push the crown inward to Position 2, then to Position 1. Turn the crown while in Position 1 to wind the spring. How many times depends on your brand, mine is 35-40 turns. Once I am done, push in the crown and turn simultaneously to lock it down. It will stop when it is seated properly.
Good luck.
Mar 10, 2015 | Watches
6617, I am unable to set the time.
yes the stem should pull out if it wont pull out unscrew it first by turning it anticlockwise then pull out,,don't forget to screw back in after you've adjusted..
Feb 01, 2013 | Charles Hubert Classic Ladies Silver Tone...
Just got a new Seiko watch but the date won't change automatically
Main cause would be that the date gear teeth have been stripped. This is done by setting the date whilst the hands are trying to change the date themselves (between 10pm and 2am). Always adjust the date with the hands around 6.0clock. You will need to return your watch to where you bought it for repair I'm afraid.
Jan 18, 2013 | Seiko watch - SXDA42 Watches SXDA42 Ladies
User manual
Sep 02, 2012 | Charles Hubert Watches
SETTING DATE JUST ROLEX
After you unscrew the crown it is already in winding position. If you pull the crown, it will go to the date setting position. Further pull of crown will set it in time setting position. Try to pull the crown till you get it in correct date setting position and change the desired date. Do not use the date setting between 10pm - 2am, as this can damage date mechanism. The best way is to pull out crown to the time setting position and set the time to 6.30(anytime) and then push the crown in to date setting position and change the date to the previous day's date. Then again pull the crown out to the time setting position and advance hands forwards (clock wise) till hands pass 12.00 (midnight) and the date changes automatically to the desired one, then adjust the time, push the crown fully in and screw the crown on.
Jun 01, 2011 | Rolex Lady Datejust 179173SRJ Watch for...
How do i set the day (Mon-Sun) on my ax2013 watch?
When you pull the crown out there are two positions. The first is the day/date setting position. Turn the crown one way and the date changes, the other direction the day of the week changes. Set both the day and date to yesterday. It will become evident why when you finish. Now pull the crown all the way out and notice when you turn the crown the hands move. Advance the hands to the 12 o'clock position in a clockwise direction. As you pass 12 the date may begin to change. If not then you now know that was noon and not midnight because the date only changes at midnight. If the date did not change advance the hands all the way around 12 hours. This will now be midnight and the date should begin to change. It may be almost instantaneous or may take until 12:30 or so. Continue advancing the hands to 4 o'clock. You should see between midnight and 4 the day of the week advance. Now the day/date are correct for today and the final step is to set the correct time. Remember, you are now set a 4 AM. Advance the hands to the correct time. That means if it is 3 in the afternoon, you must advance past noon to 3. You cannot go backwards. That would be 3 AM!
Mar 24, 2011 | Giorgio Armani A|X Armani Exchange Black...
How do you set the day of the week?
Since you didnt tell me what KIND of watch it is I am giving you a general instructions.
  • Wait until the second hand is at zero (the top of the dial). Then pull the crown knob out as far as it will go to set the time on your watch. Turn the knob in either direction and look at the three additional hands on the time dials of your watch: the minute hand, the hour hand and the 24-hour hand.
  • Step 2 Stop turning the knob when all minute and hour hands are pointing to the correct time. Pay special attention to the 24-hour hand so that you have a.m. or p.m. correct.
  • Step 3 Push the knob back in exactly when a new minute is starting so that your second hand will be correct. Use another clock you know to be accurate as a reference, such as the government clock available online.
  • Step 4 Pull the knob out halfway so you can set the date. Turn it counterclockwise until you notice the date on the watch changing. Stop it and push the knob back in to its starting position once you reach the correct one. Try to set the date before 9 p.m. If you set it after that time, it may not register with your watch that it should switch the date at midnight. If this happens with your watch, just fix it the next day.
  • Step 5 Set the chronograph, or big dial, on your watch. It works like a stopwatch to let you time activities for up to one hour. Push the top button on the side of your watch to start it. Push it again to stop it. Push the bottom button on the side of your watch to reset it.
  • It would certainly help if next time you let us know what kind of watch it is you have, Best of luck.
    Aug 11, 2010 | Watches
    Need instructions on National Geographic Men's watch #NG010GYSK
    go to Buliva web site and look for the chorograph 561/598
    FEATURES
    1. Hours, minutes, seconds and date display.
    2. 60 minute Chronograph (CHRONO) with minutes and
    seconds display.
    3. 24 hour hand, permanently synchronized with the normal
    12 hour hand.
    A. SETTING THE TIME
    1. Pull the crown out to position “3” (See diagram). If the crown has
    a “screw-down” lock, then unscrew the crown lock first by turning
    the crown toward you, then pull it to position “3”. Do not forget to
    screw the crown back “IN” after all setting is completed.
    2. Turn the crown towards you (hands moves clockwise) until the
    date changes at approximately midnight.
    3. Continue turning the hour and minute hands to the correct time.
    If it is afternoon you must go past 12 o’clock again (noon) to set
    the correct time.
    4. When the correct time is set,push crown back to position “1”.
    B. SETTING THE DATE
    1. Pull crown to position “2”(See proceeding diagram).The watch
    will continue to run.
    2. Turn the crown away from you until the correct date appears.
    3. Once the date is set, push the crown back to position “1”.
    Note: Do NOT set the date between the hours of 8:00 PM and
    3:00 AM.This would not damage the watch,but the date may need
    to be reset later.
    C. CHRONOGRAPH (CHRONO) ADJUSTMENT
    If the chrongraph second hand is not positioned at the proper
    starting position (12 o’clock or “zero” position), use the below
    procedure.It does not need to be repeated unless the watch
    receives an impact sufficient to move the hand out of position, or
    the Battery has been changed.
    1. Pull crown out to position “3”.
    2. Push button “A” to move the Chrono Second hand (long hand) to
    the “0” or 12 o’clock position. Each button push will move the
    hand one step – BUT holding the button down will advance the
    hand rapidly.
    3. Push crown back to position “1”.
    D. USING THE CHRONOGRAPH (CHRONO)
    Note:
    The maximum chrono reading is 60 minutes, However the
    chrono will continue running once 60 minutes has passed. The
    resulting one hour periods may be added together mentally to keep
    track of longer periods.
    For example – If you know that approximately one hour has
    passed since you started the chronograph, and the chrono reads
    25 minutes, then you know that the chrono has been running 60
    minutes plus 25 minutes, which is one hour and 25 minutes.
    1. Push Button “A” to start the chronograph. Push button “A” again
    to stop the chronograph.
    2. Push button “B” to return the two chronograph hands to the
    “Zero” or starting point.
    3. The Chronograph can be stopped and started again
    (Button “A”), repeatedly, to “ADD” times together.
    BOOK NO. 561/598 Chrono FS00/01/10
    Watch Setting Guide
    4/2007
    Feb 13, 2009 | Bulova Watch
    How do you set and deactivate the alarm function.
    I did find two authorized dealers:
    www.kenmarwatches.com
    www.princetownwatches.com
    Contact both and request users manual fur your specific model. They must be able to help.
    Jan 05, 2009 | Bulova Watch
    Cascio
    To sync the correct 12 hour with your day you need to set the date to the day before (if today is 21, then make sure the day window reads 20). Then spin the analog hands until the the date window turns to 21. At this point your watch is reading 12 AM (midnight). Then keep turning to set the correct time. If it is 9 am then stop the hands the first time you hit the 9 marker. If it is 9pm, then keep turning until the SECOND TIME your hour hand meets the 9 marker. This is now set for 9 pm.
    That's how you do it. If you need more clarification let me know.
    Aug 07, 2008 | Casio Marine Gear AMW320D9EV Wrist Watch
    Watches Logo
    113 people viewed this question
    Top Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Bruce Robin
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
