Question about Stoves Ovens
How to remove burner
Stoves new home 600 sidom
Posted by joseph masterman on
1 Related Answer
BElectric
DILLIGAF
  • 1140 Answers
SOURCE: I have just moved into
Hello -
Sorry for the delay in replying to you, but there has been a technical fault at FixYa and we have not been able to answer your question. I've uploaded the instructions for setting the clock and using the timer features to Rapidshare for you to download:
http://rapidshare.com/files/456163521/Stoves_Timer.pdf
Download instructions:
1. Click on the link above. The Rapidshare download page will open in a new browser window
2. Scroll to the bottom right corner of the download page and click "Slow Download"
3. Wait for the timer to count down to zero (usually about 30-60 seconds)
4. Click on "Download Now!"
5. Save the file (Stoves_Timer.pdf) to your PC.
Once you've set the clock and made sure the timer isn't active, operating the oven is no different to operating any other oven - select the function you wish to use and set the temperature using the control dials.
Unfortunately, the user manual for this oven is not available for free download, but one can be obtained from Stoves spares and accessories store by calling (UK) 0844 8153745. The manuals cost about £5 including postage.
Hope this helps. If you need further assistance, please reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Posted on Apr 06, 2011
I need an instruction manual for a Stoves 600 EM oven
Check out the manufacturer web site for manual download.
Nov 07, 2015 | Stoves Ovens
Changing the light bulb in a stoves df 600 si oven
STOVES n600 is a squair glass window which prizes our from the bottom. It looks simetrical but only goes back in one way up
Oct 08, 2012 | New World Ovens
Need instruction manual for stoves heritage 720EF cooker
Supply an email address and I will validate it on my BT Digital Vault to give you access to take a copy of the Handbook.
Nov 03, 2009 | Stoves 720EF Electric Double Oven
STOVES 600 oven door wont shut properly
open the door about 30 degrees, lift straight up to release the hinges, this will allow you to remove the door.
you will be able to assess the hinges from there.
most likely the hinges are just out of alignment
May 26, 2009 | Ovens
Manual for cooker
just wondered if u ever managed to get a manual for the stoves new home 600 si dlm ? if so,could i be cheeky and ask u to email me a link please?
thx in advance :)
Ant
[email protected]
Mar 08, 2009 | Stoves Ovens
Stoves 900G gas oven stopped working
A lot of times the problem is with a dirty or a clogged burner. Make sure the burner is clean.
If you have a pilotless model, it uses a spark igniter to ignite the gas, which works in a combination with a spark switch (located on the burner gas valve) and a spark module. Because it is not simple to test these parts and find out which one is defective, we recommend to contact a professional appliance technician.
Sep 03, 2008 | Stoves Premier 900GRa Gas Double Oven
I have a double gas oven and no instructions
I have an O'Keefe & Merritt double oven gas stove. The model number is 72 7242 23. The upper oven is about the size of a large microwave and sits above the range burners. The lower (full-size) oven is below the burner unit and includes a broiler draw below it.
So, when you say, double oven, I wonder if you are just talking about the main oven with broiler drawer (both of which are below the burner unit.)
Mine was a builder-supplied appliance in the new house we purchased in 1986. The upper oven has never performed very well. And, yes the upper oven can only be used for baking.
I have an instruction manual for it, but it doesn't provide that much information. Getting parts for it is extremely difficult, since Tappan is no longer manufacturing this brand. (I've been trying to locate a flat oven ignitor for the upper oven and can't seem to find a replacement that's the same 6-1/3" length.) In the 1980s Tappan apparently purchased O'Keefe & Merritt and marketed this brand for several years. Models originally manufactured by O'Keefe & Merritt in the 1930s-1950s are considered collectible antique stoves!
If you want to email me, I'm at [email protected]
Apr 20, 2008 | Stoves Premier 900GRa Gas Double Oven
Whirlpool electric stove
The ideal thing to do, would to be to replace the elements themselves. Most heating elements for stoves are universal and can be bought at lowes stores. I found your model number specific burner elements on a supply website for 42.00 each on the 8 inch and 35.95 each on the 6 inch elements. I am almost certain, you'll find these parts at lowes or home depot much cheaper. If this doesn't help, let me know, we will try another route.
Apr 15, 2008 | Ovens
Ovens Logo
70 people viewed this question
Top Stoves Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Anthony Ward
Anthony Ward
Are you a Stoves Oven Expert? Answer questions, earn points and help others
