Question about Turbo Air Refrigerators
My turbo air m3 freezer temperature won’t go under 44
Posted by Sophin Samreth on
Turbo air m#TSF-72SD will not hold below freezing. Cleaned coil an temp dropped to 29 but no further...
If everything else is in proper working order, either a refrigerant level issue or and expansion device issue. If system constantly runs the previous, if not, possible temperature control. Look for system cycling or not cycling.
Jan 10, 2018 | Turbo Air Freezers
M3 turbo air freezer. M3F24-1 temp on display is not temp of box
this could be a bad temp sensor or lack of proper air flow. Make sure the evap fan runs when it's supposed to be running. Also make sure the evap is not freezing up. all these items can cause what you are describing.
Aug 06, 2016 | Turbo Air Refrigerators
The temperature of my GE Model PSH23PGSD in freezer and refrigerator will not maintain 0 and 34
heat rises so if it's cold on the bottom and warm on top in freezer it sounds like you have a bad evap fan motor,when you open the freezer door do you hear the fan blowing,if not look around and hold the door switch in and see if it blows on some models fan won't run unless door is closed but if no fan you have a bad fan motor,the problem with ge is everything runs through the mother board located in the back,also i've found that the fan blade slides off or out of position on the shaft and it just doesn't move any air but you have to find out if it's the fan motor or the board,also the fridge should be set at 37 or 38 not 34,if your handy and you're going to fix this yourself,i would get both parts from repair clinic because you have 365 days to return parts,change the fan motor first if it sounds like the fan is your problem and see what happens,this way you have both parts and you can fix it that day and send back any part you don't need,if that's under 8 years i would change the fan motor,it's cheaper than the board if this is what's happening.hope this helps and good luck
Sep 29, 2017 | GE GBS18HBR Bottom Freezer Refrigerator
Why it make loud sound like fan is thatching some metal when i plug in?
check the fan blade to make sure it is tight on shaft. also check to see if any of the fins are bent could be that they are hitting the housing of the fan motor.
Jun 07, 2014 | Turbo Air MUF-48 M3 Series 2 Door 48"...
Which fuse is it for the cigarette lighter on a 98 bmw m3
1997-1998 E36 Fuse Positions:
There are four fuses (#32, #33, #37, and #44) located in the plastic front power distribution box located in the left-hand rear corner (nearest the driver) of the engine compartment that cover the cigar lighter. The numbers are marked look under box cover.
May 14, 2012 | 1998 BMW M3
My GE Adora seams to be breaking down. Freezer is not freezing and temperature in both, Freezer and Refrigerator is dropping. HAVE reset the temperatures to GE's recommendation of 0 Degrees and 38...
One thing you can do is make sure condenser coils have plenty of area around them (nothing lying against refrigerator) to prevent air flow. If possible vacuum and clean condenser coils and make sure freezer door is completely closed.
Aug 01, 2017 | GE Adora (DSF25KGTBG) Side by Side...
Freezer tempreture drop to -38F even when is set to #3
does the compressor ever stop running? If not, the trouble is in the controls. If it does, the temperature sensor is probably bad. Start there and let me know if I can be of further help.
Jan 20, 2011 | Turbo Air 49 cu. ft. / 1388 liter...
The compressor stop at 58
Change the temperature control.
http://www.acmehowto.com/howto/appliance/freezer/repair/tempcontrol.php
Dec 13, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
Refrigerators Logo
98 people viewed this question
Top Turbo Air Refrigerators Experts
Dennis Boxerman
Lawrence Oravetz
john h
Are you a Turbo Air Refrigerator Expert? Answer questions, earn points and help others
