Question about LG Refrigerators
My LG 3 door refrigerator is not cooling, it's a 3 door, freezer gets 57 degrees and the refrigerator it's not cooling at all...
Posted by Carlo on
5 Related Answers
mattozan
Matt Jurach
  • 555 Answers
SOURCE: Freezer stays cool but bottom stays warm.
I agree with your analysis, and recommend that you replace that fan between the two sections.
Posted on May 20, 2008
Anonymous
SOURCE: Profile refrigerator section not cooling
We are not sure what precipitated the temperature swing up; however, within about an hour of emptying quite a lot of foodstuffs from top and bottom sections of the unit, I felt the cold air start to flow out of the rear vent. Within two hours, the upper section had dropped to about 50 degrees and by the next morning to 36. The freezer seemed to recoved on its own too, having risen to almost 8 degrees and then recovering to 0. Just patience and a smaller food payload?
Posted on Oct 02, 2008
duby1990
Justin Duby
  • 370 Answers
SOURCE: Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Posted on Nov 20, 2008
Anonymous
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
Anonymous
  • 212 Answers
SOURCE: Amana refrigerator not cooling below 45 degrees.
the fan in the freezer section is called the evaporator fan. this fans main funciton is to blow cold air into the fresh food side. if its not running then you need to replace. make sure there is no frost build up on the rear wall in freezer section
Posted on Jun 24, 2009
Refrigerator
Most refrigerators have only one evaporator that handles both compartments. Only the very expensive ones have two evaporators that cool and independently control the temps separately.
Most simply circulate a small percentage of the cold air with a fan in the freezer section (where the thermostat that controls the compressor is getting its signal from) blowing over to the refrigerator section with the hope that that keeps things cool enough in the refrigerator section. If your LG is one of the common ones, it could be something a simple as a large object blocking the air flow between the two sections or a problem with the circulating fan. Also the dial that supposedly controls the temperature in the refrigerator compartment is sometimes connected to a linkage that determines how far a flapper door is help open or closed. Look for a problem in that linkage or damper door.
Aug 13, 2016 | LG 24.7 Cu. Ft. Side-by-Side Refrigerator...
Fridge won't cool past 57 degrees
Guessing ether a fan, damper our defrost issue. Sorry cant be much help.
Aug 19, 2012 | Samsung RF266ABRS Bottom Freezer...
Freezer works fine. Refridgerator wont get below 60 degrees.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 08, 2010 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
Freezer and Refrigerator are not getting cool enough
there is more ice built up behind the panel
defrost is not working
Jun 27, 2009 | LG 26 Cu. Ft. Side By Side Refrigerator...
We have a LG Two Side Fridge.
Look for the air ciculation regulator sliding vent between frig & freezer section open accordingly. Set both sides to #3 on dials if frig not cooling to less than 40 degrees, might need new cold/temp controller behind frig dial
Apr 30, 2009 | LG LRSC21934 Side by Side Refrigerator
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
77 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
