Question about Vtech Toys
How come no lights show on my Vtech Vsmile motion console,but it still comes on and the controller doesn't connect?
Posted by Earlean Livingston on
5 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: game not connecting when put in vsmile
Make sure the system is turned off before inserting the cartridge.
1) Press the Reset – Press and hold the ON button for about 10 seconds
2) Make sure the game is inserted far enough into the system, and that it is pointing in the right direction. You may occasionally need to clean the contacts.
3) Also, make sure you are using the supplied power cord/adapter, not batteries. Batteries cause more problems than they’re worth.
-Tha Mp3 Doctor
Posted on Jan 04, 2009
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: vsmile console can not install on to any of my tv's
Make sure the power cord is plugged in and that the red/white/yellow cables are plugged properly into the TV. Also, as you plug the red/white/yellow cables into the TV, make sure you turn the TV to the right channel - it is different for every TV. For instance, the red/white/yellow on the front of my Sony is labelled Video 2 - yours might be labelled FRONT, AUX, or something else.
Things you can try to get the V.Smile TV Learning System to work:
-Tha Mp3 Doctor
heather holmes
  • 58 Answers
SOURCE: not playing on the screen. green light is lit,
Have you made sure that the input from your tv is selected correctly. Try that.
Posted on Mar 29, 2010
Anonymous
  • 6 Answers
SOURCE: My Vtech vsmile didn't work a the time I push the
There are problems with the power adaptors. Did you use a VSmile power adaptor, or something that just seemed to fit the unit? Using the wrong power adaptor (like unknowingly plugging a Leapfrog power adaptor) into the unit can cause damage to the Vsmile Board.
Push and hold the power (smile) button for one minute, then install fresh batteries. if it powers back up, then try:
Dirty Smartridges (the game cartridges) are to blame for about 90% of VTech Vsmile products not powering up.
In some instances, the cartridge slot on the unit itself can become damaged and will cause no power up.
Kids (of all ages) can dirty a smartridge in less than a second, and render the whole system dead.
Posted on Oct 01, 2010
Testimonial: "Great job Thanks a lot i do a little clean up of my vsmile I do what you say to I need to do and now MY vsmile Work!!!!"
ministerioac
Ministerios Acm
  • 6 Answers
SOURCE: my wireless controller on a
take batteries out of console. Hold start button on console for 45 seconds. put batteries back in. press start to turn console on. controllers should work now
Posted on Dec 27, 2011
Any ideas on how to get my Vtech Vmotion controller to connect again?
take the batteries out of console. Hold the start button for 45 seconds. Put the batteries back in. Turn console back on. Controllers should work now.
Nov 14, 2011 | Vtech VSmile VMotion Wireless Controller
Instruction manual for pink vsmile tv learning game
Here is a link to the .pdf file for the owners manual(V-Motion Active Learning System)
http://www.vtechkids.com/assets/data/products/%7B5149D6B0-B9F7-487D-B6EA-4A8E6072CE76%7D/manuals/80-078810-V.Smile_V.Motion.pdf
If for any reason the link does not work go to http://www.vtechkids.com/support/product_manuals/VThen scroll to the product and you can download the users manual from there.
Oct 30, 2011 | Vtech VSmile Pink TV Learning System and 3...
My wireless controller on a vtech vsmile motion is not talking to the game. it has been a really long time since it has been played. new batteries are in. do I have to reprogram? couldn't find the...
Jul 19, 2011 | Vtech VSmile VMotion Wireless Controller
Joystick not responding on the controller - any ideas on what to try?
take batteries out of console. hold start for 45 seconds. put batteries back in. restart console. controllers should work now
Apr 15, 2011 | Vtech VSmile VMotion Wireless Controller
V-motion controller not working
v-motion controller is not working. it wont connecet what can i do
Jan 12, 2011 | Vtech VSmile VMotion Wireless Controller
The controller will not connect and its brand new out the box
Vmotion control stop working? Here is the solution: Take the batteries out of the console. Hold the start button (green) on the front of the console for 45 seconds. Put the batteries back in. Turn on the console. Controllers should work now. Good luck. It worked for me :)
Dec 30, 2010 | Vtech VSmile VMotion Wireless Controller
My Vtech vsmile didn't work a the time I push the power button never happend my batterie are test and are brand new an i try to connect direct with a power supply never work again
Sep 30, 2010 | Vtech V.Smile TV Learning System
V tech new item..motion console..worked..turned it off turned it on..wont work
make surt you did the steps in the right order. Start with the TV and Vsmile OFF.
step 1) put the cartridge in and make sure it's all the way in
step 2) turn the TV on
step 3) turn the Vsmile on
if it still doesn't work, try taking the batteries out or unplug the adapter to let it clear and then try the steps again.
Nov 23, 2009 | Vtech V.Smile TV Learning System
Toys Logo
158 people viewed this question
Top Vtech Toys Experts
ThaMp3Doctor
ThaMp3Doctor
Geoff
Anthony Ward
Anthony Ward
Are you a Vtech Toy Expert? Answer questions, earn points and help others
