Question about Home Fencing
Our Gateman III cannot be opened from the front door using the button key.It has this noise. Can someone pls help?
Posted by Elvira Bruce on
  • towiviw
    towiviw Mar 16, 2019
    II just started 6 weeks ago and I've gotten 2 check for a total of $2,200...this is the best decision I made in a long time! "Thank you for giving me this extraordinary opportunity to make extra money from home. This extra cash has changed my life in so many ways, thank you!"
    Visit site: http://Theprocoin.com
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: 2000 Grand Am SE 4-Door
This is only a possible solution to your problem. I had similar problem with my car. It turned out that the window locking toggle on the driver door not only prevented the other windows from being opened by passengers but also controlled the door locks. When I unlocked the window control I was able to unlock the door. Another possibility is the armature inside the door has come off the locking mechanism.
Posted on Jul 26, 2008
ROB
  • 858 Answers
SOURCE: 2004 Malibu Maxx - Hatch won't open either through any options
battery in the fob may be flat!
Posted on Jul 18, 2009
Anonymous
SOURCE: Latch of trunk won't open.. lots of clicking noise.
Had the same exact trouble. Changed the relay #36. Check the owners manual pages that show where all of the fuses/relays are. The fuse box for this relay is in the trunk area so I had to crawl in cuz the trunk wouldn't open. Good uck...hope this helps
Posted on Jul 31, 2009
Anonymous
  • 306 Answers
SOURCE: drivers door won't open using key, handle or push
there is a broken spring inside the latch assembally. i dont think it can be replaced but if you remove the door panek from inside you can reach the latch assabally and find the lever that the spring was operating. when you pull up on the lever the door lock will work.. attach a new spring to the lever and to the inside of the bolt that attaches the exterior door handle and you will be back in buisness. had the same problem with my wifes sport trac and fixed around two years ago and sill works fine
Posted on Feb 04, 2010
William Desautels
  • 102 Answers
SOURCE: doors dontopen or close using two rear buttons
Look for the child safety lock on the door's ,they have been turned on .
Posted on Mar 08, 2010
I have a 1999 nissan Altima i can unlock the doors
The 1999 Nissan Altima was designed with three different methods for opening the door locks. The ignition key will unlock all of the doors by inserting the key into the keyhole and twisting it clockwise. You can unlock the doors with the remote control supplied with the vehicle by pressing the left circular button with the symbol of the open padlock on it. Finally, you can unlock the doors from the inside by pressing forward on the armrest lock button, which has a symbol of a key on it.
Nissan Consult 3 III Software Professional Diagnostic Tool
Sep 17, 2014 | Cars & Trucks
Vehicle entry problem
THAT really sounds like someone is pranking you by swapping your car for another car just like it.
Aug 05, 2014 | 2001 Mazda 626
The power door locks for my 1996 Odyssey just stopped working. I can't lock/unlock the doors with either the key fob or the front door lock buttons. When you try the door lock buttons, you can hear a buz...
Sure sounds like your problem is the power door lock control unit. Best thing to do is get a replacement unit(new or used) and install it, unless you can open and fix the defective unit yourself.
Jan 09, 2011 | 1996 Honda Odyssey
The interior lights stay on because the warning lights say a door is still open but it is closed. Is there any way i can disconnect the warning light, whats the best solution
Hi, There are several causes I would look for.
Each door has a door button that indicates if the door is closed, or turns on the interior light if it is open. There are also contacts on the sliding doors that when they mate, the warning light will go off.
I would try to find the cause.
Do the following.
1 Check to make sure all of the doors are closing properly. You may have one that looks like it is, but is not.
Each door that swings open, i.e. the two front side doors and the hatch should have button switches located in the front door jam of the front doors and one for the rear hatch. Somtimes you will find more then one button.
2 Close all doors
3 Open the driver's side door. (The one that gets the most use), turn on the key but DON'T start the car.
4 find the buttons and push on them on and off to see if the warning light goes out. If it does, then the switch on that door or the door closure position or latch should be able to be adjusted so it works again. If it doesn't, go to #5
(Note: the switch may have a broken off tip, so it may be necessary to replace it. )
5 Repeat for the passenger side door. If necessary go to 6
6 Follow test for the rear hatch. (you may need someone to help on this step.
The sliding door should have some type of "button" like contacts. There may be something lodged into one of them that is giving your a faulty contact.
Hope this helps,
Happy New Year,
Mark
Jan 01, 2011 | 2003 Chrysler Town & Country
How to program my cars garage door opener buttons for my garage door.
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
May 15, 2010 | 2001 Nissan Altima
Drum light keeps appearing
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  1. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  1. Close the front cover
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Mar 31, 2010 | Brother HL-2040 Laser Printer
The Lexus car remote key control model ES300
try this:
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (DO NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Press any button on remote for a minimum of 1 second.
System should now lock and unlock doors once.
6. Close and open drivers door.
7. Press any button on remote for a minimum of 1 second. System should now lock and
unlock doors. Once to confirm programming, twice to indicate programming failed.
8. Repeat steps 5, 6 and 7 for additional remotes.
Mar 23, 2009 | 1997 Lexus ES 300
Child locks won't release
1997 ford explorer awd child safety won't open from the inside can you help
Nov 12, 2008 | 1997 Ford Explorer AWD
Home Fencing Logo
296 people viewed this question
Top Home Fencing Experts
ray gallant
Tom Chichester
Are you a Home Fencing Expert? Answer questions, earn points and help others
