Question about Power Acoustik Car Audio & Video
How do I wire a Power Acoustik MSA4-1300D Amp to a single subwoofer?
Posted by John Burrows on
Junior
    New Friend:
  • 3 Answers
It depends on how many channels are on the Amp. If it's a 2 channel you can bridge it using the positive on one channel and use the negative on the other channel. The Amp will give the sub more power bridging the sub.
Posted on Mar 10, 2019
5 Related Answers
Anonymous
  • 19 Answers
SOURCE: Power Acoustik
the amp shouldnt even lite up w/o the ground attached.
Posted on Dec 30, 2007
MrScary66613
Travis Humphries
  • 1990 Answers
SOURCE: Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Posted on Jan 31, 2009
etirbynnor
Ronny Brite
  • 655 Answers
SOURCE: How do i wire two 15 inch subs to 2 ohms
Hello familia_gome,
Those MOFO-15's have dual 1ω voice coils. So the only way you can get 2 of them to present a 2ω load is to use 1 voice coil on each one with the two of them wired in series. Using both voice coils, you can get a 1/4ω load by wiring the voice coils in parallel and then wiring the subs themselves in parallel. You'll get a 1ω load with the voice coils in series and then parallel the subs. Or you'll get a 4ω load with both the voice coils and the subs in series.
Here's a link to Power Acoustik's PDF for the MOFO's. I recommend that you check out the wiring diagrams on page 3.
http://www.poweracoustik.com/SUPPORT/MANUALS/PA-MOFOWoofer.pdf
Hope this helps.
Posted on Apr 07, 2009
Anonymous
  • 68 Answers
SOURCE: Amp is on, but sub wont produce any bass
Make sure the subwoofer is set to low frequency, make sure subwoofer and bass are enabled on the headdeck. Make sure the gain is turned up on the amp, make sure the rcas haven't come out of the back of the head deck.
Posted on Aug 05, 2009
m22loud
  • 136 Answers
SOURCE: connecting subwoofer to kac-7201 kenwood amp
from your sub connect one short piece of cable from + on one side to - on the other side using the same diameter cable as you are running to the sub from amp . this will leave you with + and - on opposite sides of speaker these will then run to the amp +to+ and - to- on the mono side of connetor which is one left + and one - right and the amp switched to bridged
Posted on Sep 03, 2009
I have power akoustik 12"
If you sub is dual 4 ohm voice coil, you can get a 4000 watt amp (which will give you 1700 watts RMS at 2ohms). The model number is OW-BAMF40001D. Hope this helps.
Aug 20, 2011 | Power Acoustik Power-Acoustik FUBAR-12W...
Amp and subwoofer problem
try using an ipod or mp3 and hook it up directly to the amp input section-if its lit up and you get sound then youre not getting signal from your deck and youll have to track that problem down at the deck-if you still dont get any sound by connecting directly into the amp inputs then you may want to check all amp settings and be sure that your set up right and if it has external fuses make sure that they are all good and if it still wont give you any sound than take it in and get it checked out-hopefully its just not getting any signal cuz if its the amp then sorry to hear it-but good luck
May 21, 2009 | Power Acoustik BAMF2000/1D Car Amp
Speakers are thumping and cracking when powered up...why?
you are better off setting your deck speakers amp to a high pass filter setting on the amp. Adjust gains to increase desired bass and clarity. Turn off loud button if you have one, that will distort your deck speakers.
Feb 13, 2009 | Power Acoustik PTID-8960 Car Video Player
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
How big of am amp do i need?
Depending on what kind of music you listen to I would say around a 1200 Watt Amp would suffice for what you are saying. Thank you for using Fix Ya! Don't forget to rate the overall answer to your question.
Jan 28, 2009 | Power Acoustik 12 1200w Subwoofer Car...
Wiring of Subwoofer
IF ITS TWO SUBS USE TWO OF THE SAME AMPS AND U WILL GET A BANG
Dec 25, 2008 | Power Acoustik FBX-15 Car Mid-Range
Trying to find out which amp. wiring kit is needed for the AWB-10 Powered Subwoofer enclosure by Power Acoustik. It has a built in 800 watt amp., with 2 10" woofers, 1 passive, 1 active.
an 8 gauge should work thats a small amp and remember that the same gauge that u put on as a power wire make sure the ground is the same gauge
Apr 05, 2008 | Car Audio & Video
Wiring the coils together
For each sub, tie the DVCs in parallel ("+"s together, then "-"s together). This will make the subs look like 2 ohms to the amp. Then, put one sub on each channel of the amp. That will put about 280W rms onto each sub, the max for the amp.
Mar 15, 2008 | Power Acoustik Power-Acoustik FUBAR-12W...
Car Audio & Video Logo
794 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Professor_V
Professor_V
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
