Question about Jet Health & Beauty
I have a jet 3 power chair that wont charge. I just replaced the onboard charger and the controller lights up and goes all the way to green but when i unplug the chair it goes dead. Yes i let it charge for 3 hrs and still nothing. What could it be?
Posted by Jim Dean on
5 Related Answers
Anonymous
  • 40 Answers
SOURCE: lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Posted on Mar 30, 2009
Anonymous
  • 32 Answers
SOURCE: I have a mpv5, when I plug in the charger it will
need to have the batteries load tested, sounds like dead cell in one or both batteries
Posted on Jul 13, 2009
Anonymous
  • 6 Answers
SOURCE: need a wiring diagram for jet 3 power chair
Look here: http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_Jet_3_ultra_om.pdf
Posted on May 12, 2010
Anonymous
  • 7 Answers
SOURCE: lights just flash on controller and wont move jet 3 wheel chair, it is the secondd row of ligths on the controller, the ones that indicate speed. They are flasing steadily
Check that you don't have the charger cord still connected or the motor disengaged.
Posted on Jun 01, 2010
HoverTech
Donna Angelo
  • 232 Answers
SOURCE: The chair won't power on and the batteries won't
After you changed the batteries, did the power chair sit unused for several weeks? It sounds more like a battery or fuse issue than a charger issue. If there are blinking lights when you try to turn the power chair on (not while attached to the charger), or it comes on then goes back off by itself quickly, there may be something else going on.
1- The green light on the charger is telling you that the batteries are not accepting any more power, either they are fully charged or they have oxidized/gone solid from sitting without being put on the charger for too long.
2-The scrolling lights on the controller when the charger is plugged in just confirms that the chair is connected to the charger, so it sounds like everything is connected properly and working. The horn will work fine when it is attached to the charger as it is getting power from the wall outlet.
3- If it was a fuse issue, the lights would not come on at all when the charger is NOT attached, even after the battery has been fully charged, which is what it sounds like is going on. The fuses can blow if you operate the chair on a slick surface or one of the drive tires spin out. The batteries will be fully charged but because the circuit is not complete, the chair will not power on.
I recommend checking the fuses and changing them if necessary. You are in luck because this is a relatively easy and inexpensive fix as they are standard automotive fuses found at any auto parts store or even Walmart for around $2 each (you need 2). The fuses are located inside the gray battery covers under the seat, attached to the leads connected to the battery cables. The straps holding the covers on the batteries are tight, you may want to use a flat head screwdriver to help release the clips. While you are down there, inspect the tread on the tires, if it is worn or slick it may need to be replaced for safety.
I hope this information is helpful to you- good luck!
Posted on Dec 27, 2010
I changed the batteries in the jet 3 ultra. Chair will work but batteries will not charge
Wall outlet bad? Charger not turned on/plugged in right? Something disconnected? Bad battery connection? Blown fuse in chair or charger? Bad battery or batteries?
Aug 09, 2014 | Jet 3 Ultra Power Chair
I replaced the battery charger with a quest charger, chair now charges but wont function i guess because of the inhibit feature how can i fix this
A few things to consider: A blown charger fuse can cause the charger inhibit to activate. Determine if all controller connections are plugged into the power base properly. If the 3-pin charger inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
May 09, 2013 | Jet 3 Ultra Power Chair
Jet 3 will not turn on but when you plug charger cord in it will light up the entire length of the battery indicator when you push the switch. Chair will still not move. Controller is a PG Drives Pilot...
the batteries are not charged and need to be replaced. The reason you have lights is because the charger is supplying power to the chair and the chair will not move when the charger is plugged in because of the inhibit function. Replace the batteries and make sure you charge before use Hope this helps
Apr 15, 2011 | Pride Used Mobility Jet 3 Power Wheel...
When I plug it in to charge it does nothing. No lights the gauge doesn't move . Any ideals ? She have had problems like this for years off and on . They send out a repair man and it will work for a short...
Could be the charger or the charger port. Do you have the offboard charger that plugs into the joystick or an onboard charger? I would suggest trying to find an offboard charger from a friend or your provider that you can borrow and plug it into the charger port under the front of the joystick to see if it will charge the batteries. the meter will not work if you use an offboard charger the lights on the charger will turn green when it is fully charged. when the charger is plugged into the joystick and you turn on the chair the lights should scroll indicating you have the charger inhibit function working and hopefully the chair is charging. If you can charge the chair with the offboard charger then look into buying one and using it instead of trying to get the onboard charger working Hope this helps
Mar 04, 2011 | Jet 3 Ultra Power Chair
One blinking light only on the controler
If its the red light on the battery meter its indicating low batteries. If you have just charged the chair and your charger light didn't turn green then you need new batteries. and have the charger checked while your at it Hope this helps
Dec 10, 2010 | Jet 3 Ultra Power Chair
My jet 3 has been sitting for 6 months, will the joystick light up when the onboard charger is in use. When I plug the onboard charger in the altameter raised to 3.5 and after charging for 12 hours drop to...
Hixx the batteries are too low to light up the joystick and no amount of charging will bring them back. Sorry you will have to get new batteries. You will need 2 U1 batteries. Hope this helps
Dec 03, 2010 | Jet 3 Ultra Power Chair
My Hoveround MPV5 batteries will not charge, do you think it is a battery problem or a charger problem?
If you plug the charger into the wall, turn on the power switch and the light comes on, the charger should be working properly. Here is a way to test it-
Attach the charger that came with the power chair to the power chair controller firmly and turn the power chair on, while the charger is running. What should happen:the lights on the controller will scroll back and forth. If this does NOT happen and you can confirm the charger is turned on, the charger handle is fully seated inside the controller receptacle and the wall outlet has power, then the charger may have a problem and needs to be replaced.
If the charger is OK, then there may be a problem with the batteries. Here are some sypmtoms:
1-You connect the charger but the light on the charger never goes red, it just stays green.
2-You connect the charger but the light goes from red to green VERY fast.
3-The charger light goes from red to green but when you disconnect the charger and press the power button on the controller, you only have one flashing red light, or the batteries drain within just a few minutes of use.
4-The power chair has been stored or sitting idle for several months.
5- The power chair has been connected to the charger 24-7 for several months.
Any of the above examples indicates that the batteries are oxidized or damaged and will most likely need to be replaced. The MPV5 takes two, U1 12 volt 33 amp batteries which can be purchased at any battery warehouse store like Interstate Batteries or Batteries Plus.
Nov 30, 2010 | NRS Hoveround MPV 5 - Used Power...
Jet 3 Ultra, batteries 1 yr old, charge voltage only 26.3 volts output from onboard charger when batts drained after extended use. After charging overnight, batts are 12 volts each, but chair goes 1.5...
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Oct 30, 2010 | Jet 3 Ultra Power Chair
Not sure if jet 3 is charging
Does all your lights on the joystick come on after charging? If you can have someone look behind your chair while still plugged in for charging, the green light on the charger will be lit if the batteries are fully charged. They will have to kneel and look under the shroud to locate the charger they will see the light if it is on. Also check the meter on the rear of the chair the meter should read zero when the chair is plugged in and fully charged. I fyour chrger is working then if the chair does not stay with power for what was normal then new batteries are probably needed
Aug 21, 2010 | Jet 3 Ultra Power Chair
Health & Beauty Logo
71 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
