SOURCE: Crane Adorable One Gallon Cool Mist Ultrasonic Humidifier
I posted the instructions for cleaning the unit a little while ago, but under a different Crane humidifier product. See http://www.fixya.com/support/t253969-cleaning_instructions
SOURCE: Humidifier mist won't come out of tube
sounds like the small fan that is located in the base isn`t pushing the mist out. unplug it then take all the screws out of the base. there are screws under the black foam stands too. be careful not to touch anything that looks like live wires while you look inside then look inside while it is pluged in. it should turn. check for something blocking it like lint or dirt..you may be able to clean around the shaft with w d 40
SOURCE: how do you change the filter in a holmes cool mist
http://www.jardenstore.com/manuals/MANUALS/HM1865-U_43_74701759.PDF
here is the website for the manual. when you download it go to the maintance section and it will let you know. if not. basically all you have to do is turn off your unit first. take the base and the tank off take out the wick filter disgard and put in new one. put everything back and turn on unit. and it should would like new
SOURCE: I have a Cool Mist V3500 humidifier. The fan
TRY POURING IN SOME WHITE DISTILLED VINEGAR AND RUNNING IT. THE VINEGAR LOOSEN UP ANY SCALE AND JUNK. AFTER RUNNING UNIT FOR AWHILE, DRAIN OUT ANY REMAINING LIQUID AND ADD DISTILLED WATER OR FILTERED WATER. RUN UNIT AGAIN. THEN DRAIN OUT ANY LIQUID. NOW THE UNIT SHOULD WORK AS NORMAL. IN THE FUTURE, TRY USING DISTILLED WATER OR FILTERED WATER.
