Question about Fujitsu Heating & Cooling
Bought new Fujitsu remote control Model AR-DL10,installed fresh batteries, but will not start the Fujitsu Halcyon Model ASU12RMLQ. Signal being sent, but no response, no beep. What should I do?
Posted by J. Othon Benavente on
5 Related Answers
harjeet singh
  • 86 Answers
SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Posted on Mar 17, 2008
Anonymous
  • 67 Answers
SOURCE: Remote Control Unit-Fujitsu Air Con. Model:AR-DL1 is broken.
If you contact Fujitsu in your country and you will be able to buy it straight from them, if they are still available. Now I have to warn you as a Fujitsu warrenty agent they are very very expensive.
I would prolly recommend getting a universal remote. ALOT cheaper
Posted on Jan 23, 2009
Anonymous
SOURCE: Remote unit slides open but cant find battery cover-model AR-DL10
When sliding the bottom part of the remote down, you have to lift it slightly (I did this with a letter opener - very carefully) to pry the door up from two stops that normally prevent the dorr from sliding down too far. If you look carefully, you can see what I mean.
Posted on Apr 21, 2009
Anonymous
SOURCE: I have a remote control unit Model : AR-RY7
Jane,if you are still interested: Go to www.fujitsugeneral.com, click consumer, click service and parts, click manuals. Enter the model number of your indoor unit = small numbers on right hand side (e.g.,asu12rmlq and put plenty of paper in your printer. I had 19 sheets. Lots of luck. Bob
Posted on May 24, 2010
Anonymous
  • 10 Answers
SOURCE: I have a model AR DL10 remote for a Fujitsu air
After changing the batteries you have to depress the RST button and if the remote has the abcd slide switch ensure it is set to A.
Posted on Jul 15, 2010
Testimonial: "THANKS"
I have a model AR-DL10 remote. One of the batteries corroded , installed new ones and now the unit will not respond. What should I do?
Pull the new batteries and clean the terminals. If cleaning don't work the corrosion may have damaged the remote. Use a PC of sand paper, or scratch the surface that the batteries touch.
Aug 12, 2015 | Heating & Cooling
Aug 1, 2015 Where can I buy Remote for Fujitsu ASU18C1 quickly?
from a fujitsu service dealer or service agent for fujitsu ac
Aug 02, 2015 | Fujitsu Heating & Cooling
In winter the outside unit sounds like a rubbing/ticking noise
Sounds like ice coming of the coil. That would explain the ticking. The rubbing could be ice buildup before the defrost cycle or it's building on the blades of the fan throwing it of balance a bit.
Feb 13, 2015 | Fujitsu Halcyon ASU12RMLQ Mini Split Wall...
Where can I find a new remote AR-DL10
Hi gdpotter,
Here's the LINK for the original remote control.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 29, 2011 | Fujitsu 24C1 Air Conditioner
Fujitsu remote control Model AR-DL10. I need to change the batteries. I can pull the slide down to expose the set/ swing/ energy save, but I think I have to pull it further down to get to the batteries. ...
How to get to the batteries in a AR-DL 10 Model Fujitsu Remote Control/ A/C
Pull it down to expose the controls inside.
To pull it down further to expose the batteries: PINCH BOTH SIDES OF THE slider at the top where it is knurled so it will bow out a little bit in the center AT the same time you may need to
slide an object under the slider to help it bow up a litter further.
WHILE DOING THIS: pull the slider further to expose the batteries. There are two plastic stops that the slider must clear to pull it down enough to get the new batteries placed. Before putting it back together: File down the two stops with a nail file so it is easier to do next time. - Who engineered this?
Sep 11, 2010 | Fujitsu (FPCRC04AR) Remote Control
I bought and installed an ASU9RLQ that had been
Install new batteries, aim it at the unit and press the power button. You should hear a beep or see a green signal. If not, try to command the fan to come on.
Jul 09, 2010 | Fujitsu 18C1 Air Conditioner
I have a remote control unit Model : AR-RY7 fujitsu for a ductless airconditioner unit without a manual. I need to know how to program it.
Apr 02, 2010 | Fujitsu FPCRC05 Remote Control
Feb 04, 2009 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
Top Fujitsu Heating & Cooling Experts
Marvin
Marvin
Dan Webster
Dan Webster
jdthefixer
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
