Question about Frigidaire Kitchen Ranges
I have a Frigidaire Gallery series gas stove, We are using propane, and when we use the oven there is Soot everywhere!! and stink. I took the oven orifice out and it is a M46-58, possibly M46-56.
Is this the correct size for Propane, or Natural Gas?
Posted by John Kirch on
Marvin
    Top Expert:
  • Frigidaire Master
  • 85,239 Answers
The gas orifices for propane are different than LP gas. Are you trying to blow yourself up?
Posted on Mar 09, 2019
5 Related Answers
Anonymous
SOURCE: ORIFICES FROM PROPANE TO NATURAL GAS
Generally you can drill the orifice out 7 drill sizes larger for the lp to naturall gas conversion... Start with 1 orifice and if you like the size flame repete as needed... cost.... free if you have a drill index!!
Posted on Sep 04, 2008
Michael Anderson
  • 172 Answers
SOURCE: Whirlpool 465 Gas Stove conversion from propane to gas?
In most cases the orifices can be removed and reversed to convert from lp to natural gas. Sometimes you will need a conversion kit and you will need to look this up by model number. 465 is the oven capacity not the model number. You can locate the model number by pulling the drawer out and looking behind it. Please let me know the model and I can let you know what kit you need. Also I should let you know that your gas company is the most qualified to convert your range, and this conversion should not be attempted by anyone who is not qualified. If this conversion is not completed properly you could be risking your life and the lives of everyone in your home, so make sure you know what you are doing!! Or get a qualified person. Good luck and please be careful making any changes to your gas appliances. Please dont forget to rate me also.
Mike Anderson
Anderson Appliance
(865)945-3808
Posted on Oct 28, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: GE XL44 propane to natural gas conversion.
your going back to natural from LP??? of so tyhere is no new orifice , but hte "hood" on the end of the bake, needs to be adjusted out"loosened", LP the "hood" is secured snugged down,
Posted on Jan 11, 2009
tom weber
  • 198 Answers
SOURCE: Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
Posted on Jan 27, 2009
Anonymous
SOURCE: Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
Posted on Jan 29, 2009
Directions how to use self cleaning over on the fridge re gallery gas stove
Hello, Joan -
Clarification: You are asking about a Frigidaire Gallery model gas stove and how to use the self-cleaning feature for the oven? If so . . .
You will find the instructions here:
https://www.hunker.com/12002208/instructions-for-a-frigidaire-gallery-series-self-cleaning-oven
If you need the user manual for your oven, you can add the model number by choosing Comment and adding the information there, so I or someone else volunteering to answer on Fixya.com can look for and provide the right link for a download of a free manual.
Note: There is more than one Frigidaire Gallery range model numbers made:
https://www.frigidaire.com/Kitchen-Appliances/Ranges/View-All/?filter=Feature02012:Feature02012
Best wishes.
Apr 06, 2018 | Kitchen Ranges
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
I have a frigidaire gallery propane stove. I just bought it a couple weeks ago. We converted in from natural gas to propane, the top works great but the ovens gives off a terrible smell whenever we use it....
THAT IS VERY COMMON,YOU HAVE TO EITHER CHANGE THE ORFFICE ON THE OVEN AS WELL OR ADJUSTED,TURN IT DOWN CLOCK WISE TO REDUCE THE GAS FLOW,THEN OPEN THE AIR FLOW WINDOW ALL THE WAY,ADJUST 1/2 A TURN AT THE TIME .....AND PRESTO
Apr 21, 2013 | Kitchen Ranges
I noticed soot in my lp gas oven that had been clean. concerned when it started to ruin my food I decided to run the self cleaning cycle again. My whole house filled with toxic soot. My eyes were on fire...
Normally soot is from a range that hasn't been converted for the gas type, like natural or propane. It may be set up for natural when you're on propane or visa versa. Has this range ever worked properly without sooting?
Sep 20, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I bought gas cook stove used. I have propane gas & I don't know what kind of gas the stove was set up for. When oven is on it smells strongly of gas, food cooked in oven has black soot on it and flame...
There is a regulator behind the bottom drawer remove the drawer.look in the back you will see a silver box that the oven fuel rail is on just below the rail there is a brass fitting that needs to be turned clockwise till it stops it can be hard to turn some times but turn it till there is no clearance between the nut part of the valve and the silver box then you can start your oven and it should work fine you can also adjust it to get a little more flame if needed.
Feb 03, 2011 | Frigidaire Gallery GLEFM397DS Electric...
Propane stove burns yellow & creates soot
clean the orfices and tubes and then if possible adjust your air mixture setting also
Sep 21, 2009 | Frigidaire FGB24S5A Gas Single Oven
How to unlock the frigidaire oven range door and remove error F3?
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
Jul 13, 2009 | Frigidaire 30 in. Electric Gallery Series...
Gas oven that cooks unevenly
clean your orifaces.
Also make sure that it's the correct stove for your gas type. If you're using a NG stove on Propane, you're wrong. It's making a lot of soot, and could potentially blow up your house. Stop using it until you're sure.
Dec 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Kitchen Ranges Logo
195 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
