Question about Boating
SOURCE: how to remove starter from 1983 30hp evinrude OMC
I just read up on the removal of your carb, It says to remove the flywheel to get more room, and then the carb, the left side bolt is harder to get to but it can be done. Only get 1/6 turn of the wrench, remove the fuel line, and be careful not to lose any throttle parts. Hope this helps.
Posted on Apr 15, 2010
Testimonial: "The main problem is NOT knowing how to remove the starter. Thanks in advance, Wayne"
SOURCE: i'm wondering if my 2003 yamaha TTR 125 is a 2
Hi and welcome to FixYa,
It uses a 4-stroke engine.
Good luck and thank you for asking FixYa.
Posted on Apr 18, 2010
SOURCE: 2 or 4 stroke engine
2 stroke.Fuel/oil ratio is 50/ 1.50 parts fuel,1 part oil.They are a very good reliable motor.Hope this helps
Posted on Jun 09, 2010
SOURCE: yamaha yz80 2 stroke or a4 stroke
2001 Yamaha YZ80 Specifications
Engine
Engine Type
2-stroke
Displacement
83 cc
Bore x Stroke
47 mm x 47 mm
Compression Ratio
8.2:1
Engine Cooling
Liquid
Carburetion
Carburetor
26mm Mikuni
Transmission
Transmission
6 - speed
Chassis
Wheelbase
49.5 in
Ground Clearance
13.7 in
Seat Height
33.6 in
Fuel Tank Capacity
1.3 gallons
Forks
Forks
33mm Kayaba
Fork Travel
10.8 in
Shock
Shock(s)
Kayaba
Shock Travel
11.1 in
Wheels and Tires
Front Wheel
17 in
Rear Wheel
14 in
Brakes
disk/disk
Other Information
Intended Use
Motocross
Color Scheme
Blue
Cost when new
$3199
Posted on Jul 19, 2010
Mar 24, 2016 | Boating
Mar 24, 2016 | Cars & Trucks
Nov 16, 2013 | Yamaha 2009 Grizzly 700 FI Auto 4x4 EPS
Sep 01, 2013 | LeoVince Kawasaki ZX-6R Ninja 2011 Carbon...
May 15, 2011 | 2006 Yamaha Warrior
May 02, 2011 | 2002 Yamaha YZ 426 F
Jul 19, 2010 | 2003 Yamaha YZ 250 F
Mar 30, 2010 | 2007 Yamaha Ybr 125
Dec 20, 2008 | 2006 Yamaha DT 125 X
124 people viewed this question
