Question about LG Refrigerators
Our LG LSXS26366S is having issues making ice. The lever that signals to make more or less ice, freezes at the bottom where it comes down.
If I break the ice off, it will make about 30 pieces of ice before it freezes again.
Posted by Christi Nellenback on
Lee Henderson
    Novelist:
  • 136 Answers
I would try defrosting the fridge and then trying different temperature settings. It could be that the water isn't freezing early enough and water drips down onto the lever.
Posted on Mar 08, 2019
5 Related Answers
ebenezer
Ebenezer Phillips
  • 25 Answers
SOURCE: frigidaire ice dispenser problem
The ice anger will be controlled by a motor system, the hummming could bea result of stuck rotor or the motor system is faulty. the motor might needs replacement.this will explain why the ice is not dispenced.
Posted on Aug 10, 2007
Anonymous
  • 290 Answers
SOURCE: Bottom of ice maker/dispenser frosting over
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back if you need more help.
Posted on Nov 18, 2007
dcp2
Daniel Phillips
  • 63 Answers
SOURCE: Water leaks from tube at the bottom of fridge for water dispenser only
If it is a plastic compression fitting you can tighten each one a little(careful not to tighten them too much cause they can strip out) Use a small crescent wrench with a back up wrench.
Posted on Jan 28, 2008
Anonymous
  • 4 Answers
SOURCE: LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Posted on Mar 21, 2009
Anonymous
SOURCE: lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Posted on Jul 12, 2009
My ice maker does not make crushed ice anymore, it comes out in big pieces and regular cubes.
Hey Barb.. does it make "popping" sounds?.. if so..the ice "bucket" shaft has broken the plastic at the drive end.. or either the blades have lost their sharpened edges or the rod that runs through the ice tray is not working...
...... I have a GE.. the ice maker broke at about 13 months..I replaced it... it broke again.. its plastic and will break again...so I get no crushed ice... just big cubes..I am not replacing again!!..
Jul 17, 2017 | Refrigerators
How do I Prevent ice dispenser from freezing up? Ice is in the ice bucket but will not disperse.
The ice stays in the cubemaker tray for a set time and then empties into the bucket. If the freezer was too warm the ice wasn't frozen enough when the cube maker emptied it and it all stuck together. Now the fridge is cold again empty the bucket, make sure there is no ice stuck in the dispenser and try again. If it is a Samsung fridge do the above and turn it off for 30 seconds and back on again. Sometimes the controller and display freezes and reads the wrong temperature.
Nov 18, 2014 | Refrigerators
Maytag H2O MFI2568AES Ice Maker keeps jamming
Most ice and water units have heater elements inside the door and in the ice chute itself to prevent water and ice from freezing in those areas. Its possible that one of the heater elements has failed. You will need a wiring diagram and a meter to test if the element is OK or not.
Feb 22, 2014 | Refrigerators
What to do if gum is stuck in your hair?
Take any kitchen
cooking oil (olive, canola,
vegetable) and apply it
to the gum and
surrounding hair . Wait
two or three minutes.
Use a comb and gently
comb the gum out of
your hair .
Wash your hair with
shampoo .
Ice Method
Mar 27, 2013 | Computers & Internet
Ice cube maker does not work what can be the poblem
first of all assure that u are getting water inside of the tray of the ice maker if you have no water then u will want to ceck in the back of the unit down the bottom a blue or white plastic piece this is called the water valve assure that u are getting water through the tube into the icemaker sometimes on some units there willbe a freeze up in the line if this is the case then you would have to defrost the line itself if your unit is getting water and u can feel ice on the inside remove the entire icemaker unit and run hot water to remove all frozen ice then reinstall your doing this becasue sometimes the gear cannot turn becuase it comes out of postion and sometimes this does make the gear go back to normal after u install you would have to wait till your icemaker once again reaches 30 degrees and then it would start making ice again if it doesnt not make ice at this point then u would have to buy a new ice maker cheapest way ton get a new icemaker is through marcone appliance parts and they will ship it to your door hope this helps
Jul 18, 2010 | KitchenAid KSCS25FKSS Side by Side...
Ice machine is only making flakey size ice. Machine is clean and filters have been changed. Water is flowing and cold; it appears that the machine is in constant operation.
sounds like there is a problem with the water in the sump escaping. Sometimes, the plastic grate under the evap plates break and pieces get stuck in the dump valve. It is a triangular piece that the pump attaches to via a hose. It is spring loaded and the pieces prevent it from seating, thus, water leaks into the drain that you will not notice. When the water level in the sump gets low enough, it goes into a harvest and drops small slivers of ice. I'd check that out first.
Hope this helps.
Feb 09, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Kenmore side by side 2000 refrigerator with water and ice dispenser. The ice does form in the tray but the piece that strips the ice from the tray is missing. I have ordered the piece to replace. The ice...
Hi, I think you need a new icemaker. What you described seems like water is getting in ice bin with the auger. Either to much water to icemaker and it overflows or if your talking about the rotating strip fingers for the icemaker is missing then yes that is the problem. If ice don't come out of tray and it still cycle it pour water on top of ice and into bin with the auger.
Sep 08, 2017 | Kenmore Refrigerators
Ice maker not ejecting ice and then tries to fill tray and leaks
The Ice Maker Tray had a small plastic piece break off. This piece aids the tray in bending to dislodge the ice from the tray. Bosch does not just sell the tray, you will have to buy the whole ice maker assembly. You will need to order Part # 0422 from Bosch. I was not very happy about having to spend $112.00 for this whole assembly when all I really needed was a simple ice cube tray.
Save the $112 and remove the ice maker. Buy Ice at the grocery store.
Mar 31, 2009 | Bosch Evolution 500 B20CS50SNS
FrigidAire Side By Side Slow IceMaker
there is no way to speed up the ice production, factory set only way to produse mor os depending on age of refig might have an "extra ice" button on display. even thats atemporary fix and probly speed up by 20--30 min
Jan 29, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
77 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
