If you have lost your remote for your DC Blue and PLUS garage door motor and need to connect a new remote, but the memory is full, you will need to reset the motor to clear the memory before programming the new remote.
To reset the DC Blue and PLUS motor, follow these steps:
- Locate the reset button on the motor. It is usually located near the bottom of the motor and may be labeled "Reset" or "Learn".
- Press and hold the reset button for about 10 seconds until the LED light on the motor flashes rapidly.
- Release the reset button and wait for the LED light to turn off. This indicates that the motor has been reset and the memory has been cleared.
Once you have reset the motor, you can program your new remote by following the instructions in the manual. If the memory is still full and you are unable to program the new remote, you may need to delete some of the stored remotes from the motor's memory to make room for the new remote.
To delete stored remotes from the motor's memory, follow these steps:
- Press and hold the "Learn" button on the motor for about 10 seconds until the LED light starts flashing.
- Press the button on the remote you want to delete from the memory.
- Wait for the LED light on the motor to flash rapidly, indicating that the remote has been deleted from the memory.
Repeat these steps for each remote you want to delete from the memory until you have enough space to program your new remote.
If you are still having trouble programming your new remote or resetting the motor, you may need to contact a professional technician for assistance.
