Question about Kohler Electrical Supplies
Wiring connection of SCR in Kohler 17 RES
I need to put a new SCR on my kohler 17RES
Posted by Iqbal Hassan on
BrianHaze
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 23 Answers
If you have an scr pack, that has 6 pins, there are two for ac, two for gates, and two for the excitation field.
The two gate wires come off your adc controller.
Posted on Apr 16, 2019
5 Related Answers
Joe Hogan
  • 10865 Answers
SOURCE: wiring schematics
Kohler has an entire technical library on their website. Go to Kohler.com and you will find it. good luck
Posted on Jan 21, 2009
rjivaro
  • 158 Answers
SOURCE: electrical wiring for kohler engine
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
Posted on Apr 29, 2009
john h
  • 23401 Answers
SOURCE: 17 hp kohler that is dumping gas out the muffler
carb float sticking open dumping gas into cylinders
Posted on Oct 19, 2009
Anonymous
SOURCE: need wiring diagram for kohler 12.5 engine and
A FREE download of the entire Kohler Service Manual for your engine is available as of 1-29-2010 on the net in the form of a pdf. I don't know how long it will remain available but as of today you can still download it allowing you to reference the area of your concern using the address; www.asberry.net/files/TP-2339-D.pdf. This pdf contains the entire Service manual for your engine. However, it is 147 pages long and if you don’t start with at least a half full cartridge it may drain your black ink cartridge. I downloaded this Service Manual for my Kohler 12.5 engine to help me fix a charging problem and it was a bargain because the download was FREE except for the ink and 147 pages of paper.
Posted on Jan 29, 2010
Anonymous
  • 3 Answers
SOURCE: I have a new Kohler 12kw res generator on propane - backfiring
Is the outside air temp cold. These generators will backfire if it is real cold and if the propane pressure is low. It is suppose to be 11 to 12 inches of water colume at the generator fuel input. drygwals
Posted on Feb 20, 2010
Where is the speed sensor located on a 20resa kohler genset
Kohler Generator issue 20 RES - YouTube
? 0:24
www.youtube.com/watch?v=CT9u64dZna0
Apr 28, 2012 - Uploaded by Jeremy vanEyk
Brand new Kohler Generator Test cycle issue. ... Oh, and Mike, good call on the carb--that happens on some 20RES models. ...Indicates Locked Rotor (Lr). ... I'm on my second 20 RES-L,home depot swapped out the 1st one. ... Kohler 20KW RESA Whole House Standby Electrical Generator - Duration: ...
May 19, 2015 | Kohler 20resa 20kw Home Emergency Backup...
Model 17 RES spec#GM51561-GAI serial #2234881 - purchased 12-10-08 - the engine loads down and turns off before finished charging - and it does it with breaker on or off and it is intermittent - does not...
If the unit 'loads down" with the breaker off as you indicated, it isn't the load, (unless someone has wired it on the wrong side of the breaker to the home) and is been overloaded. Assuming that is NOT the case you need to check the stator wires to the breaker for ground shorts, especially when the unit warms up. I had a case once where a unit had a bad stator, it would run fine then as it was put under a mild load it would just bog down like overloaded, the stator was heating up and causing a ground fault. Have the unit load bank tested also. I am interested to know what you found?
Sep 22, 2013 | Kohler 17RES 17 kW Generator
Under voltage
Check rotor slip rings,brushes then rotor and stator for shorts
Aug 08, 2012 | Kohler 17 kW Emergency Power System -...
Kohler 12K RES where are links for the installation /setup of the controller? thanks
The 12RESL has no user setup. That's part of lower cost on the DC 2200 controller versus an ADC 2100 or ADC-RES controller that came with the 12 / 17 / 18 RES models. Here is a link for the ADC 2100 Operation / Installtion manual though. http://www.scribd.com/doc/60318571/Kohler-8-5-12RES-Install
Sep 14, 2011 | Kohler 12 kW Emergency Power System -...
My Kohler Model 17RES threw an Overspeed Shutdown code. I have been unable to reset the system. It makes a short "chattering" sound around the circuit board area when I try to manually switch the...
The chattering sound is the stepper motor trying to cycle. Check to make sure there is no interference, move the throttle linkage by hand back and forth fully as sometimes the 17, 18, and 20 butterfly valve sticks on the carburetor gasket. If this happens, remove the gasket and use a file to put a good bevel (45 degree angle) in it to stop it from hitting. Thats all it takes.
Jul 23, 2011 | Kohler 12 kW Emergency Power System -...
17 KW Kohler will start and idle but will not step up to proper RPM to run the generator. Is it common for NO gas (Propane) pressure to pass through the regulator when the engine is trying to start. Or...
i think the propane regulator is controlled by engine vacuum pressure in a lot of gensets. when was the last time your valve clearances were checked? this is just a thought because if the valves are too tight it may not make the vacuum needed to open the regulator. not sure but its easy to check.
Jul 08, 2017 | Kohler 17 kW Emergency Power System -...
Hello..problem to my kholer 17res generator is that it is starting normally,but suddenly it changes its voices like much louder then its normal voice and shut down..it work fine for 2 years,i am facing...
hi
there are number of factors to your problems in this instant might be wise to get an assessment carried out by an engineer before incurring further and costly repairs
Dec 10, 2017 | Kohler 17 kW Emergency Power System -...
Feb 18, 2010 | Kohler 12 kW Emergency Power System -...
Need to know
F refer to "field" of the motor. The stationary part of the motor. they are alternate positive and negative to generate the magnetic field for the rotation of the commutator, in turn generating the output.
Apr 07, 2009 | Kohler 17 kW Emergency Power System -...
Electrical Supplies Logo
186 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
