There are only two possibilities for this problems for this tv.One: the tv incomming broadcasting signal cable wire that is plugging into ur tv Tuner signal board could be bad.U can test this out the incomming broadcasting signal cable wire is good or bad pretty easily by just plug it into another tv to find out the incomming signal cable wire is bad or good.Two: If the tv incomming broadcasting signal cable wire is good by plug it into a another tv.Than ur tv the tv Tuner signal board is the causes and the problems.The tv Tuner signal board CPU chip is bad.U can do some mechanical work like take things aparts and putting it back together again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
check that you are getting signal from the dvd player by using another tv, if it works the dvd player is fine(which u have determined anyway) also check the input on tv to ensure that the input ccty (circuitry) is working as well. if the dvd player is working and tv signal is being picked up, check all the plugs and cords. Good luck.
If the tv does all those symptoms but after some seconds the tv works and stays doing the job. THen the tv has a slow microprocessor to recognice the different resolutions or video inputs.
But if the tv cannot do anything and stay aout of signal forever. send the tv to the waranty. (no waranty? you have to use the component input instead to have digital signal reproduced
